On the topic of engineering, where do you guys get your cars engineered? And does it actually stop the popos from defecting you? I'd be willing to pay $3k or whatever for it if it does keep the hassle away, paid $1.2k of labour last time i got defected and i'm planning to have this car for a while, 3 months of ownership and been defected once already.
Had a cop behind me today, drove past some parked cars and i set off a car alarm unintentionally, 50m later he had his lights flashing to pull me over. Popped bonnet etc. etc.
Didn't give me a defect but he said if he sees me driving around again he'll defect me. Tempted to just keep some stuff in the boot and say i'm on the way to the workshop if he does see me agian.
Anyway long story short, i cannot be fked with defects anymore, i'd like to get into engineering the car.
Where do you suggest?
Edited by occxlr8ed
I had a conversation with Kahli about the engineering on her R32, she said she used a younger guy and he didn't charge her too much for the engineering of her RB26, Suspension and Bodykit. Unfortunately she didn't give me a name or contact number.
Mine doesn't vent so i guess that's fine. Damn, and my FPR is just sitting in my bay visible....
Oh and regarding rims/tyres....i've got mine dialed in with -'ve camber so they do sit under the guards, but only JUST...but that's just the top of the rim, ie. the top of the rim/tyre sits under the guard then as the camber sets in at the bottom of the rim/tyre it sits outside. Defectable?
Edited by occxlr8ed
i mean like a strut cover, so it covers the damper control so you can't see the top of the coilover from the engine bay?
He means the dust cover... (I think?) rigid plastic that fits over the top of the strut, generally you have to cut it to size depending on how low the suspension travel is
Seem to remember one being a part of SydneyKids old suspension overall group buy
-D
Edit - nope, i was wrong. He means a cover over the top of the strut pillar in the engine bay, so one cannot see the adjustable dampening control
You been defected already?
With the rims you need to calculate the gain in track, the gain in rim size and compare to standard. The modifications laws give a percentage larger than stock, do some research and you can find all the documents, or call up regency and they will tell you.
so, i let my dad take my 33 gtr to the shops (harbourtown woolworths) to get a few things for tea...
as he was left the carpark, he took off from the lights and hadnt even crossed the intersection an unmarked patrol turned his lights on and pulled him over... str8 away the cop had attitude, didnt even say hello- just said pop the bonnet sir... my dad proceeded to do so but my bay looks completly stock apart from oil filter relocation.
he then shut the bonnet and went str8 for the lil dash compartment on the right hand side where he found the turbo timer which doesnt work but still defected my dad for....
didnt mention the coil overs, tint, 3.5 exhaust, height but its regency anyway for that 1 piss weak thing...
my dad also asked sooooooo y did u pull me over- his response was "hoons drive these cars, we need them off the road"!!! my dad replied with im 53 yrs old, look at my driving record- the car is in his name for insurance reasons
cop was pop and thought he knew everything- WATEVER
anyway, should b off this fri with a few things changed over... just qwatch out around the west beach area atm
That's pretty much the attitude that I got from the po po when I got done. I was like seriously WTF. For some reason I don't think they even look at your driving record. Driving an import is worse than actually commiting murder these days
Seriously please write a complaint about that incident. The officer clearly didn't give your father any reason as to why he was pulled over. They can't pull you over just to issue a defect. A complaint won't help your situation but if every person who was issued a bullshit defect took te time to write a complaint in, maybe things might change. We shouldnt had to put up with that sort of bullshit.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
