On the topic of engineering, where do you guys get your cars engineered? And does it actually stop the popos from defecting you? I'd be willing to pay $3k or whatever for it if it does keep the hassle away, paid $1.2k of labour last time i got defected and i'm planning to have this car for a while, 3 months of ownership and been defected once already.
Had a cop behind me today, drove past some parked cars and i set off a car alarm unintentionally, 50m later he had his lights flashing to pull me over. Popped bonnet etc. etc.
Didn't give me a defect but he said if he sees me driving around again he'll defect me. Tempted to just keep some stuff in the boot and say i'm on the way to the workshop if he does see me agian.
Anyway long story short, i cannot be fked with defects anymore, i'd like to get into engineering the car.
Where do you suggest?
Edited by occxlr8ed
I had a conversation with Kahli about the engineering on her R32, she said she used a younger guy and he didn't charge her too much for the engineering of her RB26, Suspension and Bodykit. Unfortunately she didn't give me a name or contact number.
Mine doesn't vent so i guess that's fine. Damn, and my FPR is just sitting in my bay visible....
Oh and regarding rims/tyres....i've got mine dialed in with -'ve camber so they do sit under the guards, but only JUST...but that's just the top of the rim, ie. the top of the rim/tyre sits under the guard then as the camber sets in at the bottom of the rim/tyre it sits outside. Defectable?
Edited by occxlr8ed
i mean like a strut cover, so it covers the damper control so you can't see the top of the coilover from the engine bay?
He means the dust cover... (I think?) rigid plastic that fits over the top of the strut, generally you have to cut it to size depending on how low the suspension travel is
Seem to remember one being a part of SydneyKids old suspension overall group buy
-D
Edit - nope, i was wrong. He means a cover over the top of the strut pillar in the engine bay, so one cannot see the adjustable dampening control
You been defected already?
With the rims you need to calculate the gain in track, the gain in rim size and compare to standard. The modifications laws give a percentage larger than stock, do some research and you can find all the documents, or call up regency and they will tell you.
so, i let my dad take my 33 gtr to the shops (harbourtown woolworths) to get a few things for tea...
as he was left the carpark, he took off from the lights and hadnt even crossed the intersection an unmarked patrol turned his lights on and pulled him over... str8 away the cop had attitude, didnt even say hello- just said pop the bonnet sir... my dad proceeded to do so but my bay looks completly stock apart from oil filter relocation.
he then shut the bonnet and went str8 for the lil dash compartment on the right hand side where he found the turbo timer which doesnt work but still defected my dad for....
didnt mention the coil overs, tint, 3.5 exhaust, height but its regency anyway for that 1 piss weak thing...
my dad also asked sooooooo y did u pull me over- his response was "hoons drive these cars, we need them off the road"!!! my dad replied with im 53 yrs old, look at my driving record- the car is in his name for insurance reasons
cop was pop and thought he knew everything- WATEVER
anyway, should b off this fri with a few things changed over... just qwatch out around the west beach area atm
That's pretty much the attitude that I got from the po po when I got done. I was like seriously WTF. For some reason I don't think they even look at your driving record. Driving an import is worse than actually commiting murder these days
Seriously please write a complaint about that incident. The officer clearly didn't give your father any reason as to why he was pulled over. They can't pull you over just to issue a defect. A complaint won't help your situation but if every person who was issued a bullshit defect took te time to write a complaint in, maybe things might change. We shouldnt had to put up with that sort of bullshit.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
