Oh cool. Next time I get done I won't bother putting my stock cat back in, ill just use an oxy torch to heat my decat up til its red hot and see what happens.
I just pictured you doing that lol
lol. I went through Regency on my 33 once when it was defected, not knowing the greddy plenum was illegal cuz it changes emissions he reckons, thats a nightmare of a job to replace but i had to. So considering the cat is the number one factor when it comes to emissions control, i thought they would pay it closer scrutiny...just imagine if u were pulled over and checked on the spot for it would be a huge fine/money maker
I remember once when i brought a car from John Verban, Regency made me replace the brake hoses on front and rear cuz they had Japanese writing and said there wasnt aloud to be any writing on them and mine had Japanese writing on them as youd expect lol. That would be the weirdest thing ive encountered b4. Other then that i even passed regency with a big rust hole in the lower rear quarter panel (later i got fixed) because it wasnt structural.
I have never actually heard of anyone receiving this "massive fine" for not having a cat. Why do I have a feeling that it's no more than the car guy boogeyman?
EPA law says up to $10k fine - probably not enforced rigorously due to the excessive nature of the fine. Or it could come down to whether the dude at regency got laid the night before or not..
-D
Surely that fine would only be for businesses though. Like a workshop that builds cars for clients knowingly avoiding doing any emission stuff but telling the customer its all fine. A similar thing happened to Jesse James in the US, the EPA came after him for like $250,000 in fines for bikes he'd built that didnt conform to California's strict emissions laws.
http://www.skylinesaustralia.com/forums/topic/252383-i-got-pinned-for-not-having-an-cat-converter/
^Crap looks like what i said would happen did so exactly to a bloke from Vic, 1500$ on the spot fine for a de-cat. Thats deff made me think twice now, they could prolly fine that much for external gate/s and screamer pipe/s
But cops can still demand u to go to Regency then and there for a mecahnical inspection or ID check cant they or not?
No. They give you a defect notice and then you have to book the car in.
Its different in Victoria. There they'll set up an rbt station as a trap and then send cars they think are unroadworthy round the corner to workshop that they set up an inspection station at. They can hide they're unfair targeting of modified cars behind the guise of a "random" breath test.
Scandy you've got some ignorance goin on, u said u didnt know such a fine even existed, yet found out it was a 10k fine BOOM like Kirsty said stay of the crack lol
Edited by discoPumpkin
ease up mate, weve all heard of the fine, its that here in adelaide we dont know of anyone who's ever been given it. ive heard plenty of stories of people rocking up to regency not knowing about a decat and still not recieving the fine, simply being told to swap it over and come back. If you dont want to run this risk run a proper cat
Dickhead, scroll up and read again.
I said I'd never actually heard of someone being given the fine. We've all heard of the fine itself. But do we have any evidence to support anyone ever actually receiving one? No.
I then further went on to compare to issuing of said fine to the boogeyman.
Problem?
Ps, who the Hell is Kirsty?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
