Hey guys i just brought my first r32 gts-t i was wondering which turbo would be my best choice. it already has a gt35r on it an its a laggy as f*k it starts to make boost around 4300 an full boost around 4600.car has wolf3d, larger unkown injectors sard fuel reg.custom turbo manifold with external gate etc etc.After around 200-230kw.what would be an ideal turbo that makes boost around 3000? any thoughts would be greatly appreciated.
https://www.sau.com.au/forums/topic/249380-gt35r-downsizing/
Have you driven a car with that much? That turbo is rated for 300+ kws or so... that's a big drop down!
I have a VG30 turbo lieing around (slightly better then an RB25 turbo)... you could highflow it for around 220 - 230kws...
NYTSKY mate i was thinking along the lines of a gt30 when do they start to make boost?a lot of people on here seem to be using hks GT 2530. Mlr mate with the cam gears what sort of rpm do u think this would lower the boost range by? thanks
Not sure mate, I'm looking into this as I'm having the same thing going on with mine, rb25 with gt35, tuner recons it will drop between 250 to 500 rpm.
Not doing this though till next year when its going in for a rebuild so no answer on this for a while from me, sorry.
I'm sure someone on here could give you a definitive answer.
Yeah i will do some searches on that an thanks man.
Unbiased opinion.
GT3076R would be good choice
But if it was me I could not go past the Billet S56-GT3 with .63 A/R hot side.
The S56-GT3 specs are pretty dam good
The S56 compressor wheel has a 56mm inducer and 80mm Major + (ETT).
Turbine has an exducer of 56.6mm and a major of 65mm and is made of 713C Inconel
Compressor map
Turbine.
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
