righto, looking at upgrading the server case before summer hits again. currently running a thermaltake M9D.
i was looking at the lan li TYR PC-X2000B. but after killing 2HDD and 2 GPU's from heat. i need something that has good cooling properties.
at the moment there is a 40mm fan under each HDD for cooling ( 5.25 bay with a bracket) so i'm after something that has ~10x 5.25 drive bays to have enough room for the fan setup's.
suggestions?
Lian Li Armorsuit PC-P80B - 12 x 5.25" bays. Fill it with Lian-Li EX-H34 for 16x3.5" hotswap bays. Has a great cooling setup.
Ash: have fun configuring a RAID5 with a P67 ICH controller, much lulz has been had in our office the past few weeks with RAID5, P67 and Caviar Greens :D
I run a modded Perc 5/i card mate, its all hardware driven, not sofrtware. Hence it's so fken fast compared to ICHRX
I've actually got 3 still here that i picked up for a steal of a price a while back.
I'll use the 2nd card for a backup server, the other two i'll probably just sell.
its a pity how 16:10 used to be the norm, now you have to pay an effing premium for it :/
Yep, i refuse to but a 16:9.
Haven't had one for 4yrs now and won't go back. I'd soooo hard to find a 16:10
I have the Sammy 2443BW as well, great screen. Had it since Nov last year :D
haha how much is one of your PERC cards worth? software RAID can still be fairly quick for purely storage use!
Will get a 16:10 monitor when I've got my R32 running right, ATM it's more of a priority than nice things for the PC, downside of being on trainee wages!
Care to part with one? I have two - one in my fileserver, one in my esxi server - would like another for my fileserver... I got mine at a decent price on eBay with the battery-backed cache a few years back. They're rockin' cards :)
that's fairly cheap given the price of a new RAID card, and damn I was hoping you were going to use the ICH so you could find out about things like sector aligning the drives lool.
do you cards have internal or external connectors? Most of the ones on Ebay appear to have external SCSI connecters rather than internal SAS/SATA connectors
Yeah man they aren't that expensive really. Awesome value. You just need to give them a fan on 5v (cable ties FTW) and then you are laughing. I didn't put a heatsink like other crazy mofo's and mine is fine.
The 5i thread from god :)
http://www.overclock.net/raid-controllers-software/359025-perc-5-i-raid-card-tips.html
It's all there. They are SAS to SATA - internal ;)
I'm going to upgrade my computer in a couple months, this is what I had in mind..
Thoughts? Comments?
(I already have an ATI 6970 video card, plus hard drives)
Which PC store is this from?
Also what is currently the best bang for buck video card for running current games @ 1900x1200 smoothly on high/max settings?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
