I use to have a Hybrid CrossfireX setup on my PC a while ago (Radeon 5770 + GeForce GT220). The Radeon for graphics and the GT220 for dedicated PhysX...It wasn't too bad but It could be better with a better nvidia card and a more powerful PSU (I've only got 620W in mine currently)
I know that the 6970 has the Lucid Hydra Chip onboard so you can run this card and virturally any other card (AMD or nVidia) together. There is some teething problems drivers wise and scaling issues..and the some of there testing I have seen doesn't look too good but you have to remember this is very new and raw so it will take some refinement
Edited by BigDirtyJase
thats where the extra money from a 2500k to a 2600k is
still a good score but not quite as fast, are you still running 4.3ghz
Just put on my cpu cooler and o/c'ed to 4.7
Super PI dropped to 8.03s
3Dmark11 was 5650, so got a little improvement :)
3DMark Results
Apparently my PC is now comparable to similiar systems, heh.
Edited by SoFreshSoClean
awesome what cooler was that again
i have been toying with the idea of getting this
http://www.mwave.com.au/sku-18030281-Antec_KUHLER_H2O_920_CPU_Cooler_Compatible_with_Intel_Sockets_LGA_1366_1155_1156
EDIT ^^ those links are gay and you have to click it twice, open page shut page open page
EDIT just saw in the other thread a Thermalright TRUE 120 cooler
Wow, I gotta get me a second GFX card :)
not sure if you're being sarcastic...
will probably lean on the cards a bit more, but given that I'm sitting on the edge of PSU output as it is, I might hold off
Edited by bozodos
here's a result with the latest drivers; for some reason I can't push the cores any further or 3dmark freezes, strange given that could get the first card up to 950mhz :/
also swapped in a pair of Sata 2 Velociraptors in a 128k stripe :D
http://3dmark.com/3dm11/1670000;jsessionid=5hzujouc0u8l?show_ads=true&page=%2F3dm11%2F1670000%3Fkey%3Dbn39BVvDMH7dx
Anyone ever used a phase change cooler? I used one for about a week, until the moisture fried my mobo because i had the heater hooked up incorrectly :angry:
I was running 4.8ghz with an i7 920, fully loaded on prime 95 temps were less than 10 degrees.
Quick question I'm hoping someone can help me with; my asus P8Z68-V has 2 switches on it. One activates TPU (auto overclock) and the other activates EPU (a power saving feature). Does anyone have any experience with these features or know anything about them? Not sure if I should switch them on or not.
I've a similar board (P8Z68-Deluxe), I presonally don't bother with using them.
OC is best done manually anyway (espeically if you have got a i5/i7 unlocked CPU since its super easy) & as for the power saving thing... to me thats like saying I'm buying a Skyline to save petrol. LOL
  • 1 month later...
question for the nerds.
currently running a 8TB server in a Thermaltake M9D chassis. but i have managed to clear a bit of space in this room for a rack mount server.
however, i do not know a great deal about rack mount setups.
What i would like to do is transfer all the gear out of the M9D into a rack. is this possible? or would i be looking at having to buy a server board, and going from there?
I personally wouldn't recommend a rack case in a home environment. Their cooling is typically designed for an enclosed rack environment in a datacenter with cool air at the front, exhaust at the rear. They often used very small high-speed fans to facilitate their cooling - and these fans are usually very very loud.
What exactly are you trying to achieve?
exactly
It's a pity though, we have a heap of old 1 and 2 RU Xeon servers that are sitting under benches for this very reason - they are outdated but impractical to sell, and not able to be used in a home environment (without a lot of stuffing around with racks, cooling, soundproofing etc)
need more desk space, and i've never been keen on putting the towers on the ground
but if its not fiesable, then its not fiesable :). just curious to see if it was possible, as i could just mount it to the wall
Yeah rack really isn’t an option. My tower sits on carpet mate, and has for quite some time. I mean it has “legs” so its not sitting bottom surface etc. Can’t see why you cant do that. Also keeps cabling out the way.
How many drives do you have?
4x 2TB
or 8 x 1TB
Running RAID cards? Or JBOD?
If it’s just a JBOD server, a 4-bay m-itx option like this would be a good idea
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=16066
I’m not totally up with m-itx boards, so not sure if they have onboard RAID or you need a RAID card. If you do need a card/more drive space:
(ive not totally checked space/specs tho)
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=18323
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=14503
Despite what the muppets have said, yes you can get a rack case that doesn't have high speed fans and it would be fine. Decent ones are pretty expensive though and it wouldn't really be worth the money.
Yeah rack really isn't an option. My tower sits on carpet mate, and has for quite some time. I mean it has "legs" so its not sitting bottom surface etc. Can't see why you cant do that. Also keeps cabling out the way.
4x 2TB
or 8 x 1TB
If it's just a JBOD server, a 4-bay m-itx option like this would be a good idea
http://www.pccasegea...oducts_id=16066
I'm not totally up with m-itx boards, so not sure if they have onboard RAID or you need a RAID card. If you do need a card/more drive space:
http://www.pccasegea...oducts_id=18323
http://www.pccasegea...oducts_id=14503
i've noticed that when the towers sit on the ground, there seems to be more dust in the cases in a shorter period of time ( from the carpet i imagine).
at the moment both cases get a dusting every 6 months, unless i'm fiddling with them. then they get a dustout while the covers are off.
4x 2 TB at the moment. but theres another 2TB drive waiting to go in. once that goes in i'll be putting it into a RAID, probably something like RAID 5
the server was built to make use of old parts, and extra storage ofcourse.
cabinets i've seen are around $600 + freight
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
