  • Replies 2.5k
Posted Images
the japs have failed, what hope do the n00bs of 2010 have?
none and buckley's?
too bad Toyota's usual modus operandii of 'rock up, dump a shit-load of money on the problem, win' didn't come to fruition. 7 years, not once on the top podium spot. ouch
F1's a very different beast to other motorsport discilpines
So to all the proclaimers in the paddock, suggesting Kimi would be at Toyota can take a long walk off a short pier
* looks at Rusty!
Kimi back at the Fez next year.... come on Luca, sign him as your third driver
* cries into glass of scotch
no no- some of the best fun next year will involve watching the ego driven meltdown re: Alonso V Massa at Team Jihad
I genuinely LOL'd at this....
I want Alfonso to hand out some Homo-esque pit lane treatment to Massa,
Massa will then quit, and Kimi will return!
well with toyota gone I just pray trulli does NOT get a drive somewhere else. I'm sick of seeing him qually up the grid then hold up every car behind him with his lacklustre race pace. plus he's always heavy as fark so they can't get to leapfrog him in pit stops.
agree on kobayashi. he's awesome. I hope he get's another crack next year somewhere.
I would love to see kimi and token at big mac. I believe kimi would show him a thing or two. god I hope I'm right, I'd be devastated if kimi got spanked by token. that would see the poms and his head grow even larger and mean more token loving BS in the BBC commentary. :P
I dunno. he is ok. certainly not the worst guy out there, but I don't think he's the best by a long shot. he had a lucky win and had the best car for 3 seasons. without the car he's been midfield just like the rest.
I don't think I've ever witnessed a season with so much happening right to the end and past the season's final GP.
We don't know where half the drivers are going to end up, we've got teams pulling out, new teams coming in. A change in the FIA president....What next?
It's a total revamp! I'm having to check planetF1 daily just to keep up with the latest.
Now there's talk that Renault might go too. If that happens Red Bull are farked!
And where would the big Pole end up? Suddenly with a big lack of top teams Kimi might have to smarten up on his pay requests as there'll quickly be more drivers than decent seats!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
