I just bought a 32 with a rb30det in it that isn't running the VCT. Now I was just wondering if it would be possible to do this mod while the engine is in? And I'm not sure what size oil restrictors were used so could it be potentially harmful to the engine if I was to start using the VCT?
actually I just found that mine has the external oil feed done. but because I have a 32 loom I dont have the plug or wiring for the vct. Guess I need to get a plug from option1 and a window switch for the vct control
Hi JonnoHR31,
Thanks for the reply and advice.
My RB30 is not using any extra restrictors, So what ever the RB30 has in there standard.
I would assume that this is more than enough to cope with the extra supply required.
Thanks,
Adam
Hi JonnoHR31,
Thanks,
Adam
I had this - Make sure you have a decent catch can because you're going to dump heaps of oil over 4,000rpm
  • 5 months later...
due to oil being scavaged from the intake cam buckets has anyone felt the need to run different sized oil restrictors to compensate for the loss or is the loss hardly significant?. Anyhow what size oil restrictors are people using on their 30/25's whether it be internaly or externally fed?
TOMEI pump
VCT = 0.6mm
Head has the restrictors blocked and a 0.8mm feed tapped into the oil gallerey on the cold side of the head.
I have 2 x 1mm restrictors and hydraulic lifters and my vct works fine.
Be aware that works on the street or the drags may not on the track.
With stock VCT restrictor and 2 x 1mm restrictors in the head mine was fine on the street or at the drags but spewed oil on the track.
To control the oil now my restricters are 0.6 VCT, 1 X 0.8 for the head, drilled out oil returns, 2 x head drains or sump vents (if your that way inclined), catch can drains back to sump, even with this it was spitting oil a bit so I got RB26 cam covers with MINES baffles and foam inserts, I head out to Wakefield this Saturday with my fingers crossed.
The TOMIE pump was a problem as the pressure was 120 psi at 6000 rpm, so I got a regulator installed and now it sits at about 90 psi.
If your building from scratch use the R34 RB25? head as its got VCT and solid lifters (best of both worlds)
VCT works great, I disconected it and noticed straight away the car was much slower to come on to power, when I connected it again it came on good again ( well as good as a TO4Z comes on anyway)
Good luck, Mark
  • 7 months later...
My main problem turned out being the return to the sump from the front head drain and the catch can was to low on the hot side of tthe sump and oil was being forced up it filling the head thus overflowing the catch can.
Removed front head drain, put a one way check valve into the return from the catch can and increased the restictor size to 1mm.
3 track days and about 6 drag days later and all is fine.
  • 2 months later...
Would like to know if it's worth me keeping the VCT or not. I'm chasing 330 kw and want to know if its worth keeping and at which point in the rev range will there be any benefit from keeping it?? looking at running a gt35 82r highmount and external gate.
Basically my options are keep vct and stock cams, delete vct and keep stock cams, delete vct and upgrade cams unless of course i upgrade to cams which still support vct.
What are peoples experience with 300+ kw while maintaining VCT?
You want more response, keep vct...
Option 2 is stupid. Option 3 isn't necessary anymore because Option 4 is available.
NYTSKY has over 500kw with small upgraded cams
I agree, option 2 is just plain stupid and a backwards step. I'm after bulk response so i need to look into all my options right now so i make the right choice and don't have to do shit twice..
At this stage i'll be keeping the vct and stock cams which will leave me room in the future to drop in some larger cams which can support vct.
I didnt realise people were still keeping their VCT with power levels more than just slightly above stock. Most seem to jump at the chance to scrap it in the pursuit for more power and high lift cams.
I have VCT stock cams hydraulic lifters and 2 x 1.0mm restrictors - also two sump vents - one to top of catch can and one from bottom as a return (will put a non return valve in the bottom one to make sure it doesn't also fill the catch can). With this setup on the track there is now nothing spewing out. I am of the opinion that the so-called head drain is not only not draining but possibly even a cause of the problem. I don't have one.
  • 2 months later...
hi guys im currently building a 400+kw rb25/30 retaining vct
my head is currently being machined and I need to know what the maximum diameter is that I can drill out the head oil drains?
I have a -12 headoil drain also and restrictors etc but I will be doing the above also, any info or feed bad muchly appreciated
Corey
I've been building one for freakin ages. its finally running again and hopefully tuned next week.
However Im concerned about one of the comments regarding the grub screw. My first head was all welded np. but decided to use a new head this time around but it has been grub screwed this time and tapped. will this be an issue? and how long will it last?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
