hi guys im currently building a 400+kw rb25/30 retaining vct
my head is currently being machined and I need to know what the maximum diameter is that I can drill out the head oil drains?
I have a -12 headoil drain also and restrictors etc but I will be doing the above also, any info or feed bad muchly appreciated
Corey
I understand 10mm but haven't done it myself. You also have to relieve the tops of those holes and the other drains.
  • 5 months later...
Hi, i know this has been asked but i haven't seen an answer to it, has anyone got the internal VCT feed working and controlling oil issues to the head on a track engine?
what feeds are people running to the head when not using an external VCT but the internal drill feed method?
Ive never had this mod running tried it on two different engines with 1.5mm Restrictors and n1 oil pumps.
ended up doing the tried and proven method of external oil feed.
I am not sure if the internal VCT feed method got past the great theory stage. I have seen a couple of people who have tried and failed - don't remember seeing anyone who has actually done it successfully. Anyway don't really see how it relates to oil control problems - you still need restrictors at least and with RB30s I would say you need sump breathers.
hey guys im deleting vct on my 25/30 still running hydraulic lifters though, iv removed and plugged the vct solenoid in the head, obviously the bottom of the head is welded (the vct feed area). and I have 2x 1.2mm oil restrictors is there anything else I need to do?
  • 3 months later...
Hey I read on the Webbers guide page for oil feed mods and it says " R34 NEO heads can be ran without NVCS as there is a normal oil feed" Can anyone confirm this? Or do you think an external feed should still be done?
Cheers Chris
Cheers Chris
Got a link to the guide you were reading?
Oh ok well I intend on keeping vct. But must have read it the wrong way. So I'll still need the external line. Thanx fellas
I'm not saying the internal feed won't work - just that people on this forum recently have tried and failed. If you look at Webber's site (link above) you'll find instructions on how he did it.
Yea I didn't think u could do it internally. From what I read on webers I was under the impression u didn't have to run a external line, even if u wanted to keep vct as the neo operates a different way. But guess it can't so External it is. Thanks guys
  • 1 year later...
drilled from one feed to the other .. get the angle right or you could end up with oil where you dont want it
picky of where I drilled between the first 2 (intake) cam journals
Drilled and tapped the outer layer to take a bung
Dummy fitted the bung to show what it looks like finished
Head was then dissassembled for further mods before being cleaned an reassembled
Hope this helps people
Hey I realise I'm digging up an old post but can you (boost is good) or anybody else help with this mod to the neo head?
This is easy BUT how on earth to you prevent getting chips in the oil gallery below that will be spat through the motor in the future? You obviously can't get to the inside of that oil gallery easily so have you just ignored this? Can you take the plug out of the front and the ball bearing and spring etc and clean it out?
I just notice people talking about external feeds on Neo heads again in here, I can't understand why you'd go external if you can do a rock solid internal mod?
  • Like 1
You drill it with the head off and blow it out.
absolutely brilliant. i was thinkin of doing this also with mine but there wasnt alot of people willing to try it back then and also time was an issue so i went with external. might have to re-visit this! less points of failure!.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
