Is the 34 running -5's?
And they are on race fuel aren't they? Last time I was out at Russels they had drums of Sunoco or Martini or something like that
i was fairly sure they were using E85 and -5's. as it kept the response similar to how it was on the R32's engine.
1 min in mark says its running E85
Also other 400rwkw/-5 - Aaron34, pretty certain it was 400rwkw and pegged back to 380 as it was seeing extensive circuit.
tangomatt also, 415rwkw. Pics of -5s :(
http://www.skylinesaustralia.com/forums/in...t&p=4855002
dyno:
http://www.skylinesaustralia.com/forums/in...t&p=4885991
tangomatt also, 415rwkw. Pics of -5s :down:
dyno:
that is a beast! i will spend time reading thru both threads, thanks for sharing
  • 3 weeks later...
how about smallest turbo that is running efficiently for the power application = win?
where do you draw the line at being 'efficient'?
I would say running 20psi on a highflow is past its efficiency but they make for an awesome combination on a street car!
I suppose you draw the line with EGTs, going past a turbos efficiency will increase the EGTs no doubt. But I suppose if thats still in acceptable range then thats still ok. Although I would prefer to drop a few psi and get right in its efficiency zone.
yeah, you can still have fairly acceptable EGTs and be well out of the efficiency zone a lot of the time though which was sort of what I was trying to say.
sure the turbo is putting excess heat into the intake charge but it is still scavenging energy out the exhaust so its still being more efficient mechanically than an NA vehicle, but you are right, it is a nicer option to have temps etc all well under control so you can drive it around on a 35c day without issue.
  • 1 month later...
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
