^ Thats what I thought too, though I was quickly corrected..
At what point did the dump pipe become a hold back? I didn't expect to hear that, it must have been a huge amount of power!
Not really Lith. seeing 3 lb of pressure in the dump at around 5000 rpm. Bit pissed off with my piper atm. when we had the 35r on the car he built a 4 inch dump. now we have the 37/88 he goes and shoves a 3&1/2 inch pipe on it.
I mentioned it to him at the time but he seemed to think it would'nt matter. WRONG!.
He's getting a visit this morning.
Oh! and for what its worth Lith it cranked out 530 hp @ 17 lb.
So the new dump pipe will be finished today? You gonna kick his arse for the stupid downgrade mate?
I would say no chance until at least next week mike. I will be voicing my displeasure. A day lost, 3 hours of dyno time, full tank of e85 all for no result. Not happy Jan,
Its funny. 18 months ago we would be cheering. 530 on 17 wow what a machiene!
Now its....... stupid engine...... only making homo mid 500's. on under 20 pound of boost. I mean really, why even bother.
Normally people start at 20 pound, not finish there.
Not really, 5 years ago we were making 520rwhp on 17psi using BP98 with T04Z's
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
