That run was an 11.1, not bad for 320awkw huh!
If I crossed the finish line in 4th and not in 3rd on the limiter, I would have cracked a high ten...oh well, I still talk about it 3 years later
130mph is fairly fast for the top of 3rd gear with 4.11 ratios (unless you have some funky long 3rd gear ratio in the box or revving motor fairly hard)
I have the same diff ratio, revving to 8100rpm and was in 4th for a fair while and ran 132.5mph
Also with a 1.5 60ft and 130mph you should be looking at least a 10.5 or quicker (something doesn't add up at all)
Edited by SimonR32
Mmm true that, 130mph is ~200km/h which is ~7000rpm in 4th with 4.11 and a GTR Box. Can't tell the exact instruments are probably out a little, but its around that range either way
I know cause i tested it out for N1GTR out of interest for the 1000M thing later in the year.
0.4 isnt too bad, i think the new cars are down under the 0.3s, but the old cars were closer to 1, i think i remember watching on top gear they claimed the veyron required 250hp to get to 150mph and an extra 750hp to get the extra 100mph, id say you would be surprised how much power is required to overcome wind resistance at 130mph
All the speedos I've looked at are out by up to 10% at those speeds, wouldn't be suprised if the tacho was also out, always over reading.
Edited by Rolls
that thing is a light switch... must be fun though
a ute with 400rwkw... umm better buy shares in a tyre company!... might want to invest in Bonds as well... free lifetime supply of underwear
It's heaps of fun, had powercruise on saturday, the car went perfect, had the best day out at the track.
Going to run it on Wed night at willowbank and go for a mid 10, then get the boot from the officials!
It has nothing to do with the fact it is turbo or v8, the reason they have different speeds is turbo cars (skylines etc) have much better drag coefficients than V8s from the 70s, they are also usually quite a bit lighter. It has absolutely nothing to do with the engine, power is power, it won't go faster just because it is a turbo :P
yeah i know, but i have been a member of the ford community for a long time and this is common knowledge. and its not any v8, only ford 8 vs ford 6. i dont know about other makes. the turb is lighter than the 8 im pretty sure aswell.
Here is the dyno graph from Aaron's R32 GTST.
Noel's has still gotta go back to the guy who did his exhaust to fix the dump and we also think his gate is a bit ordinary so it is making it a tiny bit lazier than this one. The specs on this one are:
R32 GTST
RB25/30
Standard hydraulic cylinder head with Pon Cams
No VCT connected
GT3788R 0.89A/R
HKS 800cc injectors
Microguess LT10
Blitz ID3 EBC
Just Jap 100mm intercooler
Full 4 inch exhaust with screamer
You can see it makes 10psi by about 95kms. If we had VCT on it would be making 1bar before then. Noel has much better specced camshafts for this turbo also so when we held the gate shut, it was actually making 6psi at around 2800 and 1bar at around 3500-3600
I should have Noel's new one once we get his small issues sorted out
Standard box, nismo diff which may have been a different ratio (not sure), the drag radials are much higher profile though which would also contribute to the ET
Why didn't you have the VCT on? It is also ready a lovely graph but it would look even better again with it on!
VCT isn't hooked up on this engine. Has the solenoid but no exterior oil feed. Budget build I did for someone about 3 years ago
And yes, agreed, VCT would be awesome.
So are you guys saying that weight has no effect on your trap speed? cos' an FG would have to be at least 300kg's heavier than a GTR
EDIT make that 200-250kg's
Yeah that's true but the car in question supposedly has over 1200hp at the wheels
with 1200hp atw and just semi slicks, there is no way the mph can reflect the hp in this case. obviously there is a traction problem. you never know how much power u are missing out on until u go 4 a drive in an awd car. trust me i know !!!! thats why gtr's are so fast. even if that ford is makin only 800whp, 135mph is still low. twoogle ran 139mph and 9.95 with 500kw. all bout traction.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
