That run was an 11.1, not bad for 320awkw huh!
If I crossed the finish line in 4th and not in 3rd on the limiter, I would have cracked a high ten...oh well, I still talk about it 3 years later
130mph is fairly fast for the top of 3rd gear with 4.11 ratios (unless you have some funky long 3rd gear ratio in the box or revving motor fairly hard)
I have the same diff ratio, revving to 8100rpm and was in 4th for a fair while and ran 132.5mph
Also with a 1.5 60ft and 130mph you should be looking at least a 10.5 or quicker (something doesn't add up at all)
Edited by SimonR32
Mmm true that, 130mph is ~200km/h which is ~7000rpm in 4th with 4.11 and a GTR Box. Can't tell the exact instruments are probably out a little, but its around that range either way
I know cause i tested it out for N1GTR out of interest for the 1000M thing later in the year.
0.4 isnt too bad, i think the new cars are down under the 0.3s, but the old cars were closer to 1, i think i remember watching on top gear they claimed the veyron required 250hp to get to 150mph and an extra 750hp to get the extra 100mph, id say you would be surprised how much power is required to overcome wind resistance at 130mph
All the speedos I've looked at are out by up to 10% at those speeds, wouldn't be suprised if the tacho was also out, always over reading.
Edited by Rolls
that thing is a light switch... must be fun though
a ute with 400rwkw... umm better buy shares in a tyre company!... might want to invest in Bonds as well... free lifetime supply of underwear
It's heaps of fun, had powercruise on saturday, the car went perfect, had the best day out at the track.
Going to run it on Wed night at willowbank and go for a mid 10, then get the boot from the officials!
It has nothing to do with the fact it is turbo or v8, the reason they have different speeds is turbo cars (skylines etc) have much better drag coefficients than V8s from the 70s, they are also usually quite a bit lighter. It has absolutely nothing to do with the engine, power is power, it won't go faster just because it is a turbo :P
yeah i know, but i have been a member of the ford community for a long time and this is common knowledge. and its not any v8, only ford 8 vs ford 6. i dont know about other makes. the turb is lighter than the 8 im pretty sure aswell.
Here is the dyno graph from Aaron's R32 GTST.
Noel's has still gotta go back to the guy who did his exhaust to fix the dump and we also think his gate is a bit ordinary so it is making it a tiny bit lazier than this one. The specs on this one are:
R32 GTST
RB25/30
Standard hydraulic cylinder head with Pon Cams
No VCT connected
GT3788R 0.89A/R
HKS 800cc injectors
Microguess LT10
Blitz ID3 EBC
Just Jap 100mm intercooler
Full 4 inch exhaust with screamer
You can see it makes 10psi by about 95kms. If we had VCT on it would be making 1bar before then. Noel has much better specced camshafts for this turbo also so when we held the gate shut, it was actually making 6psi at around 2800 and 1bar at around 3500-3600
I should have Noel's new one once we get his small issues sorted out
Standard box, nismo diff which may have been a different ratio (not sure), the drag radials are much higher profile though which would also contribute to the ET
Why didn't you have the VCT on? It is also ready a lovely graph but it would look even better again with it on!
VCT isn't hooked up on this engine. Has the solenoid but no exterior oil feed. Budget build I did for someone about 3 years ago
And yes, agreed, VCT would be awesome.
So are you guys saying that weight has no effect on your trap speed? cos' an FG would have to be at least 300kg's heavier than a GTR
EDIT make that 200-250kg's
Yeah that's true but the car in question supposedly has over 1200hp at the wheels
with 1200hp atw and just semi slicks, there is no way the mph can reflect the hp in this case. obviously there is a traction problem. you never know how much power u are missing out on until u go 4 a drive in an awd car. trust me i know !!!! thats why gtr's are so fast. even if that ford is makin only 800whp, 135mph is still low. twoogle ran 139mph and 9.95 with 500kw. all bout traction.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
