Your big valves helping or hurting?
Are you using pods or an air box?
Apexi pods and hurting spool helping top end. Before the latest mods it's a pretty normal figure 400kw on 98 for a nicely built 26 with stock valves always thought something may have been holding it back considering the amount of head work iv had done.
"Clearly" shoot 4?? :)
Iv been considering returning to stock airbox to till I noticed one of my plastic turbo to afm pipes completely chewed up by a hungry possum in the shed wasn't fn happy.. If I get time in the next few months I'll return it to stock and re test id prefer the stock look.
Unless you are opening the ports to 90% of the valve head ratio don't bother with bigger than +1.0mm exhaust valves. The bigger valve head can also hurt flow in a small bore. Moreso a problem on intake though.
Yep close about 4300 on pump but I think around 3800 on e85. I still believe my +2mm Exhuast valves effect spool a bit... Not only was it a smallish outlet on the manifolds but there could have been a nasty square edge in the mix aswell I really should've matched it up earlier but got lazy...
hot damn. your spool is comparatively very good, imo. what cams? dumps? boost control info? timing?
How do you work that out exactly? :huh:
You - 175km/h @ 7000rpm (4th)
RPMGTR - 230km/h @ 8000rpm (4th)
You are doing 150km/h @ 6k, 175km/h @ 7k... So roughly 200km/h you are 8k
Meaning yours is the shorter ratio... So of course yours appears more responsive.
Ben's dyno using 5th, mines 4th gear.
Ben's getting 28.7 km/1000rpm. Std is 33.5 5th and 25.5 4th. Half way between.
Ben tends to use 5th gear as it give less gear box loss, 5th is 1:1 ratio.
Unusual he starts the dyno at 3000 rpm
isnt the idea to run the dyno in 1:1?
Depending which gear you run it will give u a higher/lower torque readout...
Hp should still be the same yea?
Though I guess depending what gear the car is in it will effect how much load is on the engine causing the curve to move left/right relative to load
No gear ratio will only change the tractive effort or the actual load through the load cell. In a perfect world the gear ratio shouldn't make a difference in measured hp or only be slightly different due to the differing thrust loading through the gearbox.
In reality even the good dynos show a slight difference between say 3rd and 4th gear probly due to unaccounted for acceleration rates.
The ramp rate is really the only thing that should influence how a turbocharged cars power delivery is plotted. Slower ramp rate gives the turbocharger longer to spool hence moving the graph to the left.
In my opinion, exactly.
Dyno's are set up to give a fixed road speed increase with time, e.g. 12 kph/sec.
If you use a taller gear the dyno stills holds the wheel speed to 12 kph/sec, giving the dyno sweep longer time from start to red line.
This then gives the turbo's more time to spool. Should give a quicker spool up , not by time but by road speed, which is what the reads.
I prefer dyno runs in rpm not road speed. This shows what the motor is doing more acurately than the unknown gearing of the car.
People on this thread do not even knowin what gear Ben's run was done.To me it seems 5th with a 4.1:1 diff. Only way to get 230 kph at 8000rpm.
He does use 4th sometimes,and 5th soetimes. He tuned my R32 GTR many years ago, great job too.
Since when is 5th gear 1:1 ratio ?
4th is 1:1 , 5th is 0.752
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
