Yes, both gervaise and I had our box's cryo treated at Dans insistence.
both car make over 400 kw's and both get dragged and circuit driven and have done for 3 years with zero gearbox issues.
Does it work, How do you prove it. You can only disprove it by breaking the box and that has not happenned to date so I'm going with a resounding yes! It does work.
Hey Noel,
Those two cars are the "For" argument that I have heard, what did it cost and what state does the box have to be in for the process ?
Cryo treatment is relatively inexpensive Mitch, somewhere around the 300 dllar mark for the complete internals from memory.
The expensive bit is obviously stripping and rebuilding the box along with new bearings and sychros as common sense would dictate.
Cheers XKLABA & NXTIME, I take it this would be them ..btw how were they for price and service ?
Company
Ace Cryogenic
Address
Barrington Road
Silverdale NSW 2752
Phone
02 4774 0256
Edited by ezy_09s
Small thing, but I don't think cryo increases strength (technically). It works by improving the weak points by ensuring more uniform grain structures. Well at least that was my memory of it from 10yrs ago when I once read about it
I'm not a metallurgist, but according to the experts at the company that perform the treatment, it strengthens the metal by 300-400%.
The only reason why a metal like this is potentially weak is because of the grain. Improving that grain structure of the metal at a base level certainly does make it stronger.
Standard gear RB20 gearbox - 640hp at the wheels
Standard gear RB20 gearbox - 380hp at the wheels in a drift car thrashed every week for 4 years and still going
R33 GTST, GTR gearboxes all making over 500hp at the wheels, 9k rpm launches on semi slicks, flat shifting, clutch dumping/kicking and general abuse
Have never broken a single one....ever
OK I have finally made it to the 400 kw thread.
Car running rb26 block and -5's
Car made on 19psi 420rwks - I'm wrapped :D
Massive thanks to Trent & Cat from Chequered tuning who tuned the car over the weekend (wouldn't go anywhere else)
Trent tuned a felxi fuel set up on my Autronic
Also a huge thanks to Tas (Power Glide GTR) for getting the car to where it is - car has turned out mint mate :)
Is cryogenics recognised or practiced by the Japanese?
I remember when I first joined this forum and reading up on this when paul diemar was using cryogenics as well as crd...it obviously is tried and proven, however, it also seems to be a thing of the past OR ppl simply dont discuss it these days.
I've always been interested in this subject and TBH if I built another engine or box, I would use this method
I have had the luxury of back to back testing :)
R32 GTR making 600hp at the wheels
Blew 3rd gear
rebuilt without cryo
Blew 3rd gear
rebuilt with cryo
still going 12 months later, same abuse
Technically it's hardness roy, which can come at the expense of strength or "toughness" also there is the question of penetration and how deep you can reach into the grain structure.
That's sort of my concern.
Blew 3rd gear
Blew 3rd gear
rebuilt with cryo
Wow, those results are quite something ..im assuming thats just using the factory gearsets in all these boxes ?
Ah apparently not .
Its just a more uniform & consistent hardness across the part.
http://www.nitrofreeze.com/cryogenic_treatment_for_motorsports.html
Ah apparently not .
http://www.nitrofree...otorsports.html
That article doesn't make any reference to the depth of penetration of the process, which was my main concern.
Further, while it is true that it can relieve internal stresses and reduce voids and dislocation in the grain structure.
All of the effects such as increased wear resistance, point to more carbon being brought to the surface and the formation of a harder outer case (Case hardening) which I would have though would come at the dentriment of toughness when you're talking about the gearset globally ?
Not against the idea at all just need to know that it will work the way I need to to.
TL;DR basically. Lol.
One of my mates just started a new job with a company that does this cryo stuff. Since I plan to do my brakes soon, I'll ask him how much to do the rotors. Might make that skim job last a bit longer, after that they are for the dust bin,
Can you confirm that boost figure please.
Proof is in the pudding. But still dubious of the 300-400% claim. Can someone point me in the direction of a good article on this?
My understanding from the old Iron Carbon diagram has always been strength-Ductility-toughness vs hardness is greatly dependent on the rates of heating and cooling etc and grain size and type. With cryo freezing you are not changing the grain structure type/composition, rather just refining the grain structure by making it slightly smaller and more uniform. So you are not increasing the UTS etc of the component, but stress relieving it so that it wont fail at its weakest point.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
