ive tried searching, but i cant really find the answer. can someone tell me roughly how much a standard r33 gtr incooler can support up to??
Im going in for a tune and im hoping to see around 360kws. should i upgrade before the tune or should it be fine?
Thanks
well i was thinking if anyone would know if itll be fine for 360 it would be people who have seen 360 and shot way past it :P
If it was so good he wouldnt have replaced it for a Greddy one in his 360kw 33 that his selling, the cooler wasnt designed for those power levels and you cant argue that it is 100% efficient. It might do the job but its not going to do it as good as a bigger unit.
Anyways not going to stir the pot, 400kw you will be hearing from me soon :P
Edited by nomnomv8
lol - I didn't replace it, it came with the car. I wouldn't waste my money on one.
We actually thought it was stock until 6 months after when I had it on a hoist/front bar off etc - given results/performance were no different to stock cooler equipped examples.
I could give you a list of cars making 380-400rwkw on stock coolers if you like? no issues at all.
Yes please
So it's proven that a standard cooler can support big power, but would a big dollar brand name one be more efficient and help to make more/earlier power?
Personal choice at the end of the day.
I wouldn't run that much power with a stock cooler and nor would I run aftermarket bov's.
Ive always based my choice on what the majority have done with their cars.
This will turn into a heated debate so let's leave it at that :)
My power, temps are no different with a GReddy core (that I didn't know I had). Guess you missed that post.
But spend big if you want on the 'big mark up' Jap items that are coming outta China at the end of the day anyway. Look forward to reading your testing and if you see any temp differences at the circuit, i didn't.
I mean I know for a fact a few local Aus 'brands' have been ex-China for over 4 years. That's another argument entirely however :)
yup i like the "brands" vs china debates they always make me giggle.
I have a spare plasmaman cooler which is a real work of art.
Has to be better than the HDI cooler which was fitted to my gtr when.I bought it back?
Ash, have u heard much about plasma man? They charge a bomb but very nice quality and they do make them onsite :)
Its not China its worse..Thailand !! Well at least one major Japanese manufacturer has gear made there.
What where the dimensions of your GReddy cooler?
This.
People are forgetting that coolers are basically a heat sink, a heat sink that's in this case 20 years old and was designed to cater for "206kw" at the fly... not almost double that at the wheels!
Common sense, a cooler thats 600 x 300 with a depth of 60mm does not have more volume than a cooler thats the same dimensions and 100mm thick and at those power levels mentioned you have to have rocks in your brain not to realise that. Look at the Nismo coolers for example I guess that their engineers are dumwits and idiots not knowing that their 100mm thick coolers are useless because some nobody from a workshop in Australia said so.
The point im trying to make is when you have already spent $10,000+ to get your 360kw+ car you think that you would do it right and invest that couple of hundred more after selling your uber cool OEM GTR cooler to a GTS-T owner..
Each to their own I guess, il do things the way they work for me, everyone is entitled to an opinion and while my opinion might be seen as "worthless spending" so be it, rather that than do what i believe is stupid and goes behind any engineering principle
I got my results with 2/3 of a standard 76mm Greddy cooler. A full one would be fine for 400kw, so would a stock GTR one as proven already. Why change what doesn't need changing is most peoples opinion.
As with stock/aftermarket radiators, thick coolers aren't as efficient at cooling as the back of it is always seeing warm air, plus you pay the lag penalty most cant afford at this power.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
