ive tried searching, but i cant really find the answer. can someone tell me roughly how much a standard r33 gtr incooler can support up to??
Im going in for a tune and im hoping to see around 360kws. should i upgrade before the tune or should it be fine?
Thanks
well i was thinking if anyone would know if itll be fine for 360 it would be people who have seen 360 and shot way past it :P
If it was so good he wouldnt have replaced it for a Greddy one in his 360kw 33 that his selling, the cooler wasnt designed for those power levels and you cant argue that it is 100% efficient. It might do the job but its not going to do it as good as a bigger unit.
Anyways not going to stir the pot, 400kw you will be hearing from me soon :P
Edited by nomnomv8
lol - I didn't replace it, it came with the car. I wouldn't waste my money on one.
We actually thought it was stock until 6 months after when I had it on a hoist/front bar off etc - given results/performance were no different to stock cooler equipped examples.
I could give you a list of cars making 380-400rwkw on stock coolers if you like? no issues at all.
Yes please
So it's proven that a standard cooler can support big power, but would a big dollar brand name one be more efficient and help to make more/earlier power?
Personal choice at the end of the day.
I wouldn't run that much power with a stock cooler and nor would I run aftermarket bov's.
Ive always based my choice on what the majority have done with their cars.
This will turn into a heated debate so let's leave it at that :)
My power, temps are no different with a GReddy core (that I didn't know I had). Guess you missed that post.
But spend big if you want on the 'big mark up' Jap items that are coming outta China at the end of the day anyway. Look forward to reading your testing and if you see any temp differences at the circuit, i didn't.
I mean I know for a fact a few local Aus 'brands' have been ex-China for over 4 years. That's another argument entirely however :)
yup i like the "brands" vs china debates they always make me giggle.
I have a spare plasmaman cooler which is a real work of art.
Has to be better than the HDI cooler which was fitted to my gtr when.I bought it back?
Ash, have u heard much about plasma man? They charge a bomb but very nice quality and they do make them onsite :)
Its not China its worse..Thailand !! Well at least one major Japanese manufacturer has gear made there.
What where the dimensions of your GReddy cooler?
This.
People are forgetting that coolers are basically a heat sink, a heat sink that's in this case 20 years old and was designed to cater for "206kw" at the fly... not almost double that at the wheels!
Common sense, a cooler thats 600 x 300 with a depth of 60mm does not have more volume than a cooler thats the same dimensions and 100mm thick and at those power levels mentioned you have to have rocks in your brain not to realise that. Look at the Nismo coolers for example I guess that their engineers are dumwits and idiots not knowing that their 100mm thick coolers are useless because some nobody from a workshop in Australia said so.
The point im trying to make is when you have already spent $10,000+ to get your 360kw+ car you think that you would do it right and invest that couple of hundred more after selling your uber cool OEM GTR cooler to a GTS-T owner..
Each to their own I guess, il do things the way they work for me, everyone is entitled to an opinion and while my opinion might be seen as "worthless spending" so be it, rather that than do what i believe is stupid and goes behind any engineering principle
I got my results with 2/3 of a standard 76mm Greddy cooler. A full one would be fine for 400kw, so would a stock GTR one as proven already. Why change what doesn't need changing is most peoples opinion.
As with stock/aftermarket radiators, thick coolers aren't as efficient at cooling as the back of it is always seeing warm air, plus you pay the lag penalty most cant afford at this power.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
