Also interestingly (this is always an interesting topic) - Nizpro only use 63mm on their 400rwkw+ XR6 setups. They are taller than a GTR item, but not as wide (they are bolt in replacement).
Now those cars have the MPH to back their power levels (130mph+ in a FG FPV), so they certainly aren't being restricted by any means of the word :)
Well different kettle of fish my friend, 4000cc motor that is capable of 400kw (lets not mention the 1000nm of torque at 3000rpm lol) at alot less boost pressure than that of our little 2600cc milk crate motors.. In saying that i dont know really know much about XR's but thats the direction that common sense seems to point me towards
No.
Now this one i will agree with you on :P
Is there a thread discussing tie down methods to hold gtr's onto the dyno properly? I will be booking more dyno time soon and want to do all the tuning in 4th so I can compare my results to what everyone else does.
What has boost pressure got to do with it? Its about the volume or air/airflow through the cooler and its ability to cool it with as low a pressure drop as possible. Coolers work efficiently when they have turbulent flow through them as all those excited air particles bounce off the wall of the intercooler and allow them to transfer heat. So by nature anything that cools will have a pressure drop across it. Otherwise a straight bit of pipe would offer less pressure drop , but of course nowhere near the cooling.
So I suppose you can make the assumption that a turbo at 18psi may have cooler outlet temps then something spinning 22psi. But hp is hp and requires a certain amount of cfm to achieve. So whether its a 4L at 6,000rpm or a 2.6L at 8,500rpm...an intercooler doesnt care or know the difference. It just has to pass air and cool it
Check our card's channel on YouTube. You will see how jim ties his gtr's down on his clips.
Usually runs a loop inside the cabin with both doors open and ties it towards the rear of the car.
Yeah Ive seen that method before. I'll have to see if the shop I use have ancors on the floor behind the doors.
Your 5 th is 1:1 though Ian as is R32/R33's 4th. Although you have a slightly taller diff ratio.
True, but I've noticed that a lot of the other R34 dyno sheets in circulation (from known tuners like Racepace and RIPS) seem to be done in 4th. The only reason I want to use 4th is for comparison purposes. Roller speed maxes out around 200km/h in 4th at about 7500 rpm from memory.
Dyno sheet in RPM rather than road/roller speed?
My dyno sheets have had both so far.. but the sheets I am aiming to compare too don't. And while 4th gear vs 5th gear results should produce very similar power figures, the torque and boost response curves are completely different. On the street I'll get full boost at 4500, but on a dyno the car wants off the rollers if it is loaded up at 12km/second to achieve the same response curve.
lol Dan! :D
i love how you ask loaded questions when you know the answer - i know, ya know.
I know Racepace do use "dyno wheels", just a set of R34 GTR rims with tyres for a lot of cars when doing comparo's etc. That way at least everyone uses the same rim/tyre combo. Also so that people don't have their semi's chewed out given the cars that go in there.
I think doing it that way is a good idea for parity sake. Im not sure other workshops do the same, however I've seen some that do so depends where i guess.
So because this thread is full of sooks who want NA response and big block Chev amounts of torque rather then old school kick in the ass when the big single hits....I am curious to know of those making 400rwkws, what power are you making at 4,000rpm and 5,000rpm.
Agreed.. you wouldn't think changing the intake would be a restriction though would you.. you think that would be the least of the restriction...
Anyhow - just pointing out they 'change something' when getting up to those levels.
I'll have to do a back to back myself someday just for interest. I'd like to log the intake temps and pressure drop over a known 'load' etc and see what happens.
3500 RPM = 140 RWKW
4000 RPM = 190 RWKW
4500 RPM = 260 RWKW
5000 RPM = 350 RWKW
5500 RPM = 395 RWKW
Peak power is 426 @ 7500 RPM
8000 RPM = 415 RWKW
Have you got the same figures for GT-RS's handy?
I only have these figures on me right now;
3000rpm = 150rwkw
4000rpm = 235rwkw
Thats compared to the old setup;
3000rpm = 70rwkw
4000rpm = 120rwkw
Should add, not that it's slow, but these numbers are done with the wrong cams, i'm certain a cam change will net a bit more gain but with a new engine on the way the current one will stay as is and nothing be changed on it before its removed and stored somewhere
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
