I think I found the solution, they have a fitting similar in a way to what you've said. I've been meaning to swing by MSCN for the last few days but haven't had the time.
Hows your R34 build? Texi ready? (secretly hoping, I love watching you belt the shit out of the courses at Texi haha)
thats good to hear.
going slowly, finally got the oil pump last week and now trying to figure out how I'm going to do the external feed to it and keep the aircon. otherwise all thats left after that is the harmonic balancer, electric oil pump and the braided lines for turbos,breathers,pump and cooler. still a ways off yet
hahaha yeah texi, not this one unfortunately but was going to PM you about maybe helping out, but won;t know till closer to the day. wanting on a answer about a job in Gladstone
Mates 34 gtr
2.7 litre nitto motor
T51r kai
Vipec ecu
All the support goodies
600rwkw on E85
Granted its not anything as good as r35, I know this first hand haha
At what boost was this? Ill guess over 30psi?
Yep, AMS Alpha 12 kit. Minimum boost possible is 23psi. In the states they have the same kit running 30+ psi and they're pushing out around 970Kw at the wheels, crazy stuff.
out of interest and something I've always wanted to find out, what power level can the r35 take before it starts to break things and become unreliable?
I know the answer the answer is reliant on the mechanical sympathy u have for the car, surely there is a happy medium though :)
i remember reading somewhere people were finding 600-650hp were pushing the limit of the standard rods? but that probably relates to motorsport applications, rather than street cars i would assume.
not much different than rb rods?
With all due respect though, would you run 600cc injectors in your 650hp car just because they will probably 'be ok'?
Everything will suffer mechanical failure due to stresses eventually. There is no point putting a limit on them because at the price of a set of Spool rods, it's not even worth discussing their limit
:huh: given GTR rods have been proven to hold more, one would say yes - but end of the day who knows.
This is the 400rwkw thread, not the "what is the weakest part of a R35" thread.
Gtr rods are strong yes in rb's, I agree
Yes r35 is off topic but it sure qualifies in the over 400kw thread
GTR rods are strong. No the rod bolts aren't. For the $100 changeover in price it's stupid to even consider staying standard.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
