Squeezed my in-bred 25/26 tonight. 446kw @ 1.5bar
RB25neo with 2.6 crank/pistons @ 9.5:1CR
260 9.15 Cams with VCT
GT3582R .86 rear
Dry sumped
Sucrogen E85
Vipec ecu
nice!!
what internals were used in the build if you don't mind me asking?
block machined , balanced , honed oversized 0.20
crank , remachined and re heat treated , oversized acl race bearings
rods , shotpeened and prepped rods with oversized acl race series big end bearings
pistons arias forged 0.20 oversized with acl race series rings ect
tomei oil restrictor
cossworth 1,5mm drag series metal head gasket
n1 water pump
nitto high flow oil pump
nismo low temp thermostat
trust oil filter relocation
tomei sump baffles/trap doors
brand new gasket set throughout
head reconditioned with
hks step 2 cams and valve springs quite lumpy
slight porting on exhaust side
greddy adjustable cam gears
turbos , brand new garrett -5 turbochargers
hks non turbulent dump pipes
twin 3inch up pipes with 3inch magic cats (100cfm)
single 3.5inch high flow system
5inch rear cannon
autogallery yokohohama/os giken 1-5 gearbox , custom double cone syncros , hd mainshaft , hd input shaft , one piece billet 5th gear built by terry at award in sydney,,,
brand new os giken twin plate clutch
vspec active rear lsd and axles ect
nismo 320kmph dash
apexi power fc commander with hand controller
blitz ebc
injector dynamics modified 1000cc injectors on standard rail
turbosmart adjustable fpr
bosch 044 pump
splitfire coilpacks
hks dli twin spark amplifier
tien adjustable suspension
Stock RB26 including stock cams
Precision 6262 .8 twin scroll
6boost twin scroll with twin tial 38mm gates
Custom dump and plumb back pipes
LINK ecu
ID2000 cc injectors in stock rail
Walbro 400lph
Running semi slicks on the dyno too
Gate pressure
E70
  • 1 month later...
thought i'd ask in here as opposed to starting a new thread.
Midori has some 90mm front pipes now... i've got 80mm ones and not 100% on what mm the catback is... given the increased kw #'s we're putting out with E85 etc... would there be much gain in going to some 90mm front pipes? or is it waste of time unless the rest of the system is 90mm??
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
