480kw on vp 109 and dash 5s @ 23psi, BACKED UP with repeated 140+mph runs. It can be done, just not by many :D
Mark32 being on powerplus rated at 108 would be pretty damn close to vp race fuel, i dont see why every one is getting their panties in a knot. Edited by linkems
I don't understand what the issue is. e85, increasing boost later in the rpm range, and 'at the limit' tuning probably explain the nice graph
20psi @ 4700rpm sounds very good, but reasonable
700Nm @ 5000 rpm sounds very good, but reasonable
nobody else even talks about, let alone posts graphs, about increasing boost with rpm. that's probably the main reason for the high peak power.
Finally someone with some backed up proof.
How much does your car weigh? I suspect you have more than 480kw
the specs from that video:
HKS 2,8l stroker kit + twin GT2860-5 + nismo intake plenum + greddy 264 cams + 1000cc RC injectors + Apexi D-Jetro + Almasi tuning
the scale on the torque curve looks wrong, but the power curve looks accurate
http://www.gtrpwr.co...thread.php?t=62
Edited by black bnr32
Yeah most people don't, but sometimes it's gotta be done because everyone else around then expects it to be "the norm"... And then we end up with more and more threads like "why am i down on power", when in actual fact they are perfectly fine... They are just expecting something that's not reasonable and trying to explain this to such users can be about as productive as belting ones head against a wall (similar to telling the GTX/500rwkw person that it was not possible, but we were all haters :/)
And for the record, there are no mini-me's running around that i know of :ph34r:
If you think thats BS, i know one person who got "498rwkw" out of -5's on PUMP and when i asked him to back it up with MPH he said its an inaccurate way to calculate power! the fark lol.
There is a guy in NZ that claims mid 500kw on pump on GT2860Rs who is a fairly respected track racer etc, which sounds like crap - even on a high reading dyno. The trap speed argument has come up but he has no interest in drag racing, conveniently.
We have no interest in believing him then
Dumb comment old boy
Maybe this engine is just more efficient than all the others using the same turbos hence the higher power....
And saying that the 1/4 is the real dyno works to a degree if you have traction. But what if your running street tyres and no traction at all like Marks 32 could be wheel spinning across the line in 5th gear and still run under 120mph....
But we also have nice clean air down here in Tassie....
Edited by WHITER33GTS-T
He also has a 2.8 maybe even a 3.0 bottom end.
Different ball game to the normal 2.6
Yet another keyboard god that knows everything from behind the computer screen just ask him....
Try geting some real world experience old boy instead of just reading the interwebs then thinking your an expert on everything
The clean air must help a shit-load Rob, and you know better that anyone a lot of cars have been on that dyno and he's not the sort of bloke to produce stupid unrealistic dyno results.
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
