Stao do they remain the nvcs the same as poncams? Why not just use drop in poncams? I'm fairly sure they have been proven to make 500atw's kw. Where are you getting the camshafts from? Should sound fairly angry. :)
Josh
Engines got tomei cams 260 9.5 already with about 10000kms on them,doing a 500kw build and hoping to get there with them.Tuner said its possible so spose will try.Was just wondering on all your opinions.Will be running 30psi boost with a 2.8 stroker
On Tomei's website RB25det Pon cams is only available in 256 / 8.5mm, The 264 / 8.5mm is apparently an custom item that needs to be ordered. I've been told they are the largest drop in Pon cams, CJmotors stock them. Part no.: 143021
For those with more dedicated track cars, what's the most boost you're running through your -5's?
I'm running 23psi (moves around a little upto 24). Was thinking of upping it to 25 or 26psi. Thoughts?
Will I see much of a gain or have they already run out of puff by then?
Thats with a big $$$ head and rb2.8 stroker also. Piggaz has absolutley pushed those -5's to the moon and back. It's a awesome effort.
Josh
Josh
From memory, if we pulled it back to 25 ish psi it made something like 455. Not a hell of alot to be had top end, the gains were through the midrange. It's quite noticeable too.
  • 4 weeks later...
I ran a washable originally but now run twin ryco filters as they are super fine and my fuel system originally was dirty so the rycos collect everything.
Ps- I am not worthy of posting in your thread as my HTA hasn't got what it takes, but fark it I was passing by :P
I use a washable mesh Aeroflow one seems to do the job well..
So iam in the market for a new exhaust looking at 4" and titanium if i can find it. What options are out there? I have emailed bread at Pro Fab about a custom made one any other options? Will be on HKS 2530's with a Racepace twin 3" into 4" front pipe.
Thanks
Matt
I'll ask brad if he can do a better price for two...I'm keen for something lighter and better flowing.
Car gets tuned at unigroup on Monday. Finges crossed all goes well, Hopefully i can stay in the club....it was tuned elsewhere before and was never convinced of the power figure.
How big is your exhaust now? I spose at the most it would only be a touch up tune with the bigger exhaust.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
