Stao do they remain the nvcs the same as poncams? Why not just use drop in poncams? I'm fairly sure they have been proven to make 500atw's kw. Where are you getting the camshafts from? Should sound fairly angry. :)
Josh
Engines got tomei cams 260 9.5 already with about 10000kms on them,doing a 500kw build and hoping to get there with them.Tuner said its possible so spose will try.Was just wondering on all your opinions.Will be running 30psi boost with a 2.8 stroker
On Tomei's website RB25det Pon cams is only available in 256 / 8.5mm, The 264 / 8.5mm is apparently an custom item that needs to be ordered. I've been told they are the largest drop in Pon cams, CJmotors stock them. Part no.: 143021
For those with more dedicated track cars, what's the most boost you're running through your -5's?
I'm running 23psi (moves around a little upto 24). Was thinking of upping it to 25 or 26psi. Thoughts?
Will I see much of a gain or have they already run out of puff by then?
Thats with a big $$$ head and rb2.8 stroker also. Piggaz has absolutley pushed those -5's to the moon and back. It's a awesome effort.
Josh
Josh
From memory, if we pulled it back to 25 ish psi it made something like 455. Not a hell of alot to be had top end, the gains were through the midrange. It's quite noticeable too.
  • 4 weeks later...
I ran a washable originally but now run twin ryco filters as they are super fine and my fuel system originally was dirty so the rycos collect everything.
Ps- I am not worthy of posting in your thread as my HTA hasn't got what it takes, but fark it I was passing by :P
I use a washable mesh Aeroflow one seems to do the job well..
So iam in the market for a new exhaust looking at 4" and titanium if i can find it. What options are out there? I have emailed bread at Pro Fab about a custom made one any other options? Will be on HKS 2530's with a Racepace twin 3" into 4" front pipe.
Thanks
Matt
I'll ask brad if he can do a better price for two...I'm keen for something lighter and better flowing.
Car gets tuned at unigroup on Monday. Finges crossed all goes well, Hopefully i can stay in the club....it was tuned elsewhere before and was never convinced of the power figure.
How big is your exhaust now? I spose at the most it would only be a touch up tune with the bigger exhaust.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
