That was bound to happen considering it is a small turbo (especially hot side) for such a serious engine, same result with that other fella posting in the RB30 section.
I agree, I'm running a 6466 on my RB30 and I have not had the need to go over 6000rpm yet, on low boost. Turbo is well and truly whistling away by 2500rpm
  • Like 1
265/35R19
Can't even imagine how ridiculous GTRNUR 3.3l is to drive
I was seeing about 5lb at 2000 rpm and 18lb aroudn 3400 before it was tuned properly, so it it would probaby be even better than that now. Although now with the 10lb gate springs springs the gates bleed little until max boost is reached so it will be a little more laggy. Something I hope to have remedied soon.
I'm ~5-700 later than you. 2000 and above you can feel the turbo working. Great combo IMO.
I'm impressed with mine,yours would/will be/is next level again
3L+ and the 6466 is a killer combo.. Here's what I was seeing during some early road tuning of my setup... 3.4L, 6466, 1.0AR
26psi, 3600rpm loading it in 4th... will make 5 - 6psi instantly in any gear if the revs are over 2000rpm.
Do you have issues with fuel overheating on long drives of 2hours plus?
I drove mine for 2.5hrs trips 4 times in one weekend a month or so back with a Magnafuel Protuner 625 running a -8 feed and standard return lines, was no issues with heat
  • 1 month later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
