the panasonic looks great. are you coming to deca?
imo the gopro is good for what it is. as long as you can compress the video well, it comes out ok.
i've found the sound is best through headphones (although that maybe because of the crappy laptop speakers.)
  • 1 month later...
Here's a couple of vids from Lakeside last week.
Specialised Driving Services kindly placed a new V Box Video in my car for a couple of session, I'm mighty impressed by it! Not cheap, but SDS is looking at putting on a rental fleet of these systems ;) Could be the go I reckon :down:
I just had a look at my datalogs from targa. top of mount claude i changed to 5th 7500rpm 216kmh. i know at symmons 8500rpm gets the car to 230-235. big whales need big tall gears :P
does the vbox have multible audio tracks? eg one with, and one without comms
  • 4 weeks later...
Was doing a bit of homework today and need to get a setup for the end of the month. Came accross the HQR2 Recorder with Sony HQ Camera kit. See ... http://www.dogcamsport.co.uk/hqr2-head-camera-package.htm
Is there any real difference between the Pov 1.5s 720x480 and this cameras 720 x 576??? It is more compact and easy for me to get at present
Is that in 5th gear Sav Man ?? And a GTR ?
Have you changed the diff ratio or is that stock?
Edited by Tektrader69
just ordered a sony high deff 270 gig hard drive
should be here next week
takes 12 mega pixel stills as well
also has a gps antenna so you can track where your going on google maps
should be good
Make sure you get a memory stick for it Pete.
The hard drive will lock itself when it detects vibrations.
Other than that it's a good camcorder.
