Hi everyone. what would be the best engine specs for a r33 gts-t using rb25det that is for the track. i guess what i mean is.... whats the best combo for power to weight. i'm not just after kw i want to built (or stock standard ?) a reliable/strong/ balanced/smooth rb25det engine for track and drift. .... i was thinking neo with minor mods, am i right?
Age old question - how much power and how serious about weight reduction...
one does offset the other.
The motorsport section does have some good threads on this actually - have a check through that section also mate
A 2835 bagging you about 260-270rwkws or perhaps a 30307ProS running a bit less boost using the std manifold would be my pick for a reliable and quick track GTSt.
Oh, and sick R31, the DJR Sierra was quicker over a lap in qualifying :( The VL Walkinshaw beat it at Bathust in 1990 so lets not take this off thread on the first page. :P
If this is a serious thread then i would do as follows:
Strip the car completely
Cage
Good suspension package
Larger sump
Upgraded oil pump
And all the bolt ons for about the 450hp range.
Should be a fun track car. And relatively cheap.
"A circuit car for the track"
:blink:
lol
On a more serious note, by what you've written I am guessing you haven't been to the track many times.
I would suggest going to the track lots of times and slowly modding the car in the process so its right for you...
End goal for a track car- make it as light as possible which will mean you need smaller brakes and less power to go fast than keeping it full weight. You will also chew through less R compound tyres which are very expensive.
Mods: Wide wheels with good R comp tyres, I would then probably stick a hks2835/garrett 3071R t3 with cams and supporting mods and get some proper suspension, swaybars, camber/toe/castor rods and put a good set of pads and then just keep winding in more boost until you have enough power.
I would do the suspension and brake modifications first before adding any more power at all. Its pretty hard to learn in a car that is too much better/faster than your ability. (evo exempted :P)
buy my car and put an oil cooler on it, strip interior and maybe go stiffer in the suspension... HKS 2835, Brembos, R34 GTR wheels, Cusco diff, swaybars, Bilsteins (too soft for serious track work), Hi Energy bigger/baffled sump, N1 pumps, GTR rods, etc etc
seriously I am taking delivery of a GTR on Fri so I want it gone... 14K and its yours, another 1-2K spent on it and you have yourself a nice package
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
