Now I say test because I'm using an application on my iPhone to test this. I was expecting <14.3 but have been getting between 14.4 - 15.1 depending on launch.
The reason i expected a certain time is due to a friend of mine getting a 14.4 i believe, in a bunky piece of shit s13 CA18 running like a brick who to all of my knowledge drives terribly.
The application asks for certain parameters and I put my weight as the stock 1320kg + my 75kg + a tank of fuel 60kg = 1455kg which if incorrect will effect the outcome, does this weight sound about right ?
also i think i could probably get faster because its listing my 60ft time on my best run of 14.42 as 2.57 sec, i understand that's quite high ?
my question is should i expect a faster 1/4 mile with these mods:
3" turbo back exhaust
3inch stainless intake with pod
FMIC
never dyno'd but this application says 160rwkw on my best run
also does that time sound unusual for the S13 ?
Ill post graph of run if anyone is interested, also its called dynolicious if any of you want to check it out.
https://www.sau.com.au/forums/topic/253470-r32-rb20-14-mile-tests/
  • Replies 63
Posted Images
0-100 km/h = 6.43 sec
0-160 km/h = 13.87 sec
60' = 2.57 sec @ 45.2 km/h
1/8 mi = 9.51 sec @ 130 km/h
1000' = 12.18 sec @ 149.6 km/h
1/4 mi = 14.42 sec @ 166.3 km/h
max G's = 0.60 G's
peak power = 160rwkw
does this all seem consistent or should i worry it isnt accurate ?
if it is right, looking at my 60foot and final speed do i have much room to improve ?
if this thing is right, you can do in the high 13 sec. 2.57 60ft time sucks, you need to get in the 2.0-2.2 and you'll hit 13.
thats what i thought, was expecting a 0 - 100 closer to 6 than i been getting. Having trouble launching with traction. very inconsistent. dunno weather to dump it on launch at a lower rpm or ease off the throttle at a higher rpm
might also need some new tyres. ive had the same crappy no name ones on since i bought the car. keep putting off RE01's till i get new wheels >_>
Take it to a real strip. Where are you managing to run a 1/4mile on the street anyway? 166kmh is well over the speed limit :thumbsup:
P.S. with 183rwkw I ran a 13.9 @ 103mph, 2.3sec 60' (no traction in 1st).
Edited by bubba
Bubba, he said he's doing it on his iPhone (ie it's a simulation).
thrtytwo,
A RB20DET only puts 160kW at the flywheel, and only when it's new. I doubt with your minimal mods you would have 130kW at the rears.
The weight only comes into the power calculation, so the acceleration time should be reasonably accurate as long as the hardware and software are up to it.
If you run at the track use the iPhone as well to compare and post up results.
Yeah the weight shouldn't matter unless you are wanting to estimate power - the time etc SHOULD be fairly ok if the phone is mounted well and the road is good etc. We tried out my mates Dynolicious setup on his iPhone and the results seemed all screwed though I had a look through the settings and the rollout was "0" etc which can make your 60ft/ET etc look worse than if you ran it at the strip. Check the config and see if the rollout is set to something sensible, 166kph should have you in the 13s.
Things like GTimers come default with sensible rollout and "start timing" g-Force settings so are a bit more realistic from the outset.
I say track it and really find out.
To be honest I think the iphone meter is way off.
An exhaust and FMIC has your Rb20 pulling 103mph over the quarter? That is big MPH for not many mods!
Considering stock is low 90mphs at best, thats is a massive increase.
Not ragging on your car but I believe it is far off being accurate.
My 34GTT pulls a 14.0 with a cat back and boost, at a best trap speed (not on the quickest run) of 99mph, for comparison.
Also on topic, 2.5 seconds for a 60ft is pretty slow, but its not easy to get it right. Anything near the 2 flat is doing pretty well. Whatever you shave off in the 60ft, double it and thats what will be off your time by the end (generally speaking this is pretty accurate)
If your car really is hitting 166kmph, you should be well into the 13s!
thrtytwo,
No, I think he's using an app on his iPhone which uses the GPS features to time himself. It's not all virtual :)
I managed a 100mph on my first drag day of my life with my rb20 with only exhaust & fmic, stock boost at 10-11 psi. and my clutch started to slip on 3rd gear..
Really? Whoa... there are some major discrepancies with results in the drag area. I know there are many variables and we are talking about 20 year old cars which doesnt help, but thats good mph.
On the same track (We race at benaraby raceway) my mates SR sil, hiflo turbo, cooler, zorst, 17ish psi boost managed 98mph. Obviously you would expect higher if you are pulling 100 with such minimal mods, considering the SR has bucket loads or torque.
Without coming up with excuses most cars seem to be abit down on what they should be at Benaraby.
Then again, a dead stock JZX100 Chaser was pulling 94ish MPH, which is pretty much the same MPH I was pulling back when I first got the 34. Hmmmm its interesting. But from my expericences of sitting and watching/racing against, most 32 skylines with coolers and boost are not coming near 100mph.
Congrats to those who do though, you are obviously making some good power ;)
Well out of 3x 32's that I personally know over here all making the same power (my RB30 making an early 250rwhp, and two mates with RB20's sporting 25 turbos and all the usually bolt on stuff.. one untuned the other a de+t tuned), we've all run 102/103mph.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
