Hey guys&girls,
just blew my stock turbo in my 33 its a 96 series 2.
I just put a r32 actuator in and it read 1 bar within 5 minutes she made a pop/whistle noise!!!lol
Now i was just wondering what i should do,get it fixed or buy a second hand one?
I just want one that will cop 10pounds all day everyday without issues.
Any ideas would be great,cheers
https://www.sau.com.au/forums/topic/253966-just-blew-my-turbo/
that would be nice but not too good for the coin side of things, all i want it 10 pounds and im happy,maybe even 12 for as less as possible...........so im thinking another stocker and a decent boost controller will do the job????
what does 10 psi mean? bragging rights?
Run whats safe for the turbo, its not about a number.
Its either replace the stock one, with another stock one for less than 1k.
Or do an upgrade, decently, and spend about 2.5k
Just luck of the draw. Mine takes 15 psi everyday and i drive it hard pretty often.
My advice would be to get another second hand one. Can pick them up for 300 pretty easily. And thats all it will cost you if you are prepared to install it yourself. If not then the cost will probably double to 600..
as said luck of the draw, in my old 180 rb20det i punished it, wouldnt do it knowing what i know now, but it had a ca18det cooler, (thinner than std r32) and was running 1 bar for just over the year that i had it and i thrashed that thing every day, then sold it to a mate and it kept on living until he wrote it off
Im well aware of whats safe, whats not.
Just saying to ensure you run whats safe, and forget about the number (safe or unsafe).
Im not negative, just making a comment to the above, maybe you take that negatively... considering your record on the forum that comes as no surprise.
If you're lucky enough to find one get a R34 neo turbo, comes with the VG30 sized larger rear housing but a nylon compressor wheel meant I didn't notice any lag compared to my S1. I made 4kw more at 10psi compared to 12psi on the S1 R33 turbo. They go for $400-450.
if it were me (eventually i will be in your situation with my series 2) I would park the car for a few months, use public transport if you can or find other ways to get around untill you can afford to put a new upgraded turbo in. I don't mean go all out and put a massive high mounted lag macker in it, put if you get another second hand (suposable good nick) turbo, you run the risk of it stuffing up on you again, you have no idea what life a second hand stock turbo has gone through. they are old, they can fail even if they have minimal play and look and feel fresh. Just buy another decent turbo (brand new), or take your turbo and get it highflowed for about $800 ive seen. Highflows arn't the answer for running massive power, but its more than enough than what you need it for, fairly cheap compared to a new turbo (highflow is basically a newer better turbo of the original and run higher boost).
me personally if i had the money i'd go a new better turbo.
but its your decision
if it's going to take a few months to save up for a upgraded turbo, then it's probably not such a good idea.
the reason for upgrading usually would be more power, which in turn can cause more things to break...
get another good condition stocker on there, run 10psi, and you'll be fine. ;)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
