not a very original sign in... :P ^^^
you know the real DRDRIFT is on here regulary?
Lol, I thought that too!
I'm going for the -9's on my R34 after a lot of reading, previously had 2530's on the R32, but wanted more spread so to speak, and not aiming for 350+kw.
well ive had my number plates DRDRFT for over 10years. plus look at the date i signed up to sau....i aint gonna change it because sam is also known as dr drift....
Seriously though, no beef from me. Was just a thing that stood out, lots or similar user names on here anyways :P
What do we think the -9 is capable of? My GTR is only a daily driven thing so I don't want it running 22psi with 400kw. I was thinking when I get them all installed with injectors etc to suit, to be running a high boost of about 18psi (seems to be a good figure to keep the standard 26 alive) and a low boost setting of 14psi.
14psi= 250rwkw
18psi=280-300rwkw?
If doing mods later and you want more top end, as I plan to, I reckon they really aren't laggy. Then again I had HKS 2530s before so maybe I'm just used to it? I much prefer this kind of delivery to the stockers anyway.
My old GTR which I built 5 years ago had all the normal (saftey not power goodies, forgies etc... and had a set of HKS GTRS, on its maiden tune it made 366.9Awkw @22psi, not laggy.
Lost my licence so sold it but could off got alot more out of it with more tuning.
Now I just got the bug and have just started a new build on another GTR. this time with money being hard, i have opted for -10s, motor has internal saftey work but still running standard fuel system! til i get more money. @10psi i am 300Awkw...this is only stage one and when funds allow will be upgrading fuel system and than start to play again. Not as responsive as previous setup at the moment but not a lag bomb. Anything over 3800rpm and she will start to boogie...I cant make a definitive answer yet til I turn up the boost but so far it feels like even though the -10 is rated the same as the HKS GTRS, I dont think on the street it will preform on par with HKS? But only time will tell....
I think people are too fused about how much boost is safe on the street, It is all to do with tuning, Big turbos doesnt mean lag if setup and tuned right!
My old supra ran 577Rwkw@over 2bar boost, as a daily drive, turbo was bigger than my head and everybody said it will be laggy as hell, but I am also a lazy driver and I can tell you that it was not laggy, no need to drop gears, just excelerate and spin to my hearts content... IMO its all in the tune. Did go to calder just for fun and she pulled [email protected] spin 3/4 track...But that was with full tien drift setup....was not setup for quater...
Dr Drft...
My -10s out performed my previous hks gtrs setup :P
When I built my engine, I was tossing up between the -10s and a t04z and I stuck with -10s for a number of reasons...my tuner told me at the time its either u go -10s or a t51r as he can tune a t51r to come in about 1000rpm later than the -10s so yes I agree with u, tuning plays a huge part in response. Also noted if its tuned for response u sacrifice top end and vice versa.
Although Im running a rwd rb26, Im very happy I decided to go with the -5's rather than the 7's. I have been in a couple of gtr's that are running built motors with the 7's and in my opinion although they are super responsive they seem to run out of steam in the upper rev range.
Using the -5's with poncams and vi-pec on only 14psi my car made 325rwkw easily and pulls as hard at 8 grand as it does at 4 grand with massive amounts of mid-range.
Positive boost is cranking by 2 grand and by 3000rpm its fully into it. After having a RB20 in the car previously this feels like no lag at all.
I realise that once i wind the boost up it will have slightly more lag, but I can deal with that if I can reach the magical 400rwkw whilst still on 98RON.
My 2 cents.
These are the prices I've been quoted for the 2860s. Probably going to go with the -9 for the great medium between the -5 and -7. Also I have no idea why Garrett don't make the -9 and -10 with actuators not included in the bundle.
They did make the "-9" included with actuators.....it is known as the 780371 -1 .... notice the same chra number.
http://www.turbobygarrett.com/turbobygarre...9R_780371_1.htm
I believe your stock act will work as well but i have no idea how they will respond compared to the garretts that come with the new turbo
i guess the clear distinct advantage here is you can keep your working stockers or sell them when you buy a pair of new turbos
whereas if you highflow your old ones, you take them off, send them and get them back later
if price was the same
i would go a new pair %100
instead of highflowing originals
I'm aware that high-flowing something is a little annoying for the mechanic involved, however my point was, as per hypergear's post:
RS has different turbine wheel. Probably not much more in HP, but lot more torque. We've been using those 2x types of CHRAs in our 300zx turbo developments. Very noticeable amount of difference on road, The RS gives stronger pulling sensation while both turbos made within 2KWs difference.
In reference to using a 2860RS core on GTR turbo's. So the extra torque / approx power level is what I'm referring to.
I found a little info on the 300ZX forums but I'm not a member there and they do have 3litre engines.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
