When I bought my -5's I only paid $2100 via MTQES in wetherill park (syd) and at the time hks gtss's were almost double that...there is money to be saved. You will need the gasket kit and also don't forget about a set of actuators which set me back another $450 with brackets. You will then be set
well if the garrets are $2100-$2500 a pair and actuators are $450 a pair, plus gaskets, other fittings they are pretty close to HKS GTSS which are around $3000 or so (from memory) which includes HKS actuators, all gaskets and fittings etc. the HKS ones do seem to be more nicely finished too.
Not even close to the same ATM :)
Nengun has them listed currently @ $3400 given the exchange rate has gone to the pooper. Way more than -9s with actuators/gaskets right now. Add postage, tax... You'll be pretty close to 4k landed.
Which is around $800-$1000 more @ this point in time.
I do not get it are you happy that they are more expensive or happy because you corrected someone on an internet forum?
beerbaron is correct.
as per rhd website, GTSS complete kit comes 262,395 Japanese Yen = 3,306.18 Australian Dollars (much better value for money)
And what about the $300+ in tax that you'll are potentially going to cop? :rolleyes:
You can get -9s locally for around $2800-$3000. That's complete with gaskets ($100) & actuators ($250).
If you paid $450 for 2 actuators, then you were stung yet again. They are $250 from GCG every day of the week.
The HKS Kit costs $300 more before it even leaves Japan. Add freight, add Tax... Even conservatively you've paid $3700
All for what?
A spray-on HKS logo on the 2 actuators. That's it. There is no other difference.
The HKS Kit is only comparative when the dollar was above 95, which when it was - the HKS kit was a good buy.
All for what?
ive 'never' paid tax & ive bought most of my gear from japan on all my gtr's ive owned.
my actuators were not standard, they were setup with a heavier diaphram's to make them equivalent to the hks actuators (base release was 17psi from memory). nothing beats hks actuators & this not my personal opinion btw.
difference between garrett & hks is another debate and also depends on who you ask...
HKS actuators with the GT-SS kit are not 17psi base. They are 14-14.7psi outta the box. I know because I have them on my GTS-R.
They are identical to the ones you buy counter from GCG, just with a little HKS logo sprayed on.
What debate? The GT-SS and Garrett -9 are identical in every way.
Anyone that says they are different doesn't know what they are talking about
well then ive been taken down the garden path by GCG & 3 other workshops who all told me that hks actuators are not the same as GCG items - i had this problem when my rb30 was on the dyno & saw it with my own eyes.
the debate has already started with hks v's garrett lol
SS's -9's
Compressor Wheel
GT25 GT 25
Compressor Wheel (mm)
44.46 - 59.41 44.46 - 59.41
Comp Trim
56T 56T
Comp AR
0.42 0.42
Turbine Housing
T25 T25
Turbine Wheel
GT 25 GT 25
Turbine Wheel (mm)
42.4 -53.85 42.4 -53.85
Turbine trim
62T 62T
Turbine AR
0.64 0.64
FROM GCG
Ball bearing
Oil & water-cooled bearing system
T25 turbine inlet flange with threaded bolt holes instead of traditional through holes
GT Series oil drain flange
Turbine housing has a unique "compact" 5-bolt outlet that is not interchangeable with traditional T25 5-bolt outlets
Turbine housing is cast from high-nickel "Ni-Resist" material for extreme application
Actuators not Included
Turbine wheel is cast from "Inconnel" material for extreme applications
0.64a/r turbine housing
0.42a/r compressor housing
$1376.77 each (then minus SAU 10% = $1239.10)
X 2 = $2478
+ dains and gaskets = $216
+ actuators = $216
TOTAL = $2910
* The above assumes you are a SAU Member
SS kit from Nengun via the slowest snail mail I could find was $3572 delivered
Same fkn turbo, same shit. With the $662 (if you dont get hit with tax which normally you dont but who knows) you can go and buy yourself a set of poncams or some cam gears and a some cheap skank for the night. :thumbsup:
Funny thing is -5's come with a 15.5 PSI actuator for exactly the same price!
If you wanna be a real hard arse you can go the -10's for $1633 each but they dont come with actuators. We all know what a awsome turbo those bad boys are!:nyaanyaa:
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
