Makes you wonder how the Mines R34 GTR is so responsive using 2530's on a 2.6ltr engine doesn't it?
Fact is - it's not.
Once it's on boost (4500rpm or so), the ONLY reason it rips through the gears, is because the diff ratios were changed.
Can't believe the last 6 pages, talk about rubbish...
Suppose we should not discuss or try to help someone who asks for advice or opinion with some innocent banter in between. Oh well sorry. Didn't mean to distress anyone. So where do you suggest we discuss different twin setups? Maybe a forum is not the place. Can you suggest anywhere else?
  • 3 weeks later...
I know who guy who has done a heap of head work with his -5s and pushed a 474awkw With Dyno papers to show me when I was shocked... That thing is a rocket!!! He runs it 440awkw every day and only sets it at the highest when need to
I myself with all stock internals & -5s on 18psi running 330awkw
Edited by GTRAAH
^^^ that's me mate :P
That's pretty funny !!
What would -9 s on e85 with forged internals, cams, exhaust be looking at reaching (power wise)
Probably max the efficiency of the -9s and maybe achieve around 370kw, if your setup is good enough
With the right setup you can achieve 330-350kw on 98
There's one bloke on here making 370kw on -7's so I'm sure you could get there on -9's with the right set up.
If I can make 325kw with standard actuators, AFM's and a shitty 3" exhaust I'm sure you could make a fair wack more with a decently set up car.
You really won't be able to screw enough boost into it to make a huge difference with the -9's. they just run out of puff.
This.
The -7s and -9s by 7500rpm are falling off and simply out of airflow, so you can't screw more boost in if they simply cannot supply the air needed.
Joy of having them come on so early, can't have it all!
You can make near enough the same on 98 as you can on E85 with -9s IMO, hence my earlier comment stands... Add to the fact there is not one person who's ever made legitimately more than that :thumbsup:
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
