right guys i have most my stuff now here is a list
hks 3037 pro s
hks hi mount
power fc with boost control
tomie timing gears
660cc injector
billet fuel rail
greddy copy intake
Q45 throttle body
braded turbo lines
greddy intercooler
tail 38mm wastegate
nismo timing belt
z32 afm
fuel reg
anyway im think i should do copper head gasket before fitting all up so its done as im going for 280-300 rwkw on stock motor as im unsure if stock head gasket will hold up to it as boost will be up around 20psi
Edited by mattsr31
How long is a piece of string.
All depends on tune, health of engine ect ect.
People have run up to 300rwkw with no problem. If you want to get serious about more power then budget for a rebuild incase the sh1t hits the fan.
IBTL
If it's copper the don't seal water that well, great for compression but crap for water, what most people use is steel multi layer head gaskets copper are real old school. standard gaskets in rb30's have been used to 450rwkw+, most people only change from stock because they have the engine apart and why skimp out on a head gasket
so there is no need to worry about it till i need the head off is that what ur saying mate
3 studs in the exhaust side broke when taking manifold off as long as i can get a drill in there i wont need to remove head
what studs are best for replacement of old stock ones
many people run standard i mean nissan head gaskets with no problem with massive boost and swear by them, I run a cometic steel head gasket and would recommend using one but don't wory about it until it's apart or till the gassket blows (highly unlikely unless there is a problem) I would use stock studs but arp might make something?
I wasnt and arnt after 280kw (250kw eventually will be nice) but i still went along in my project (3.5yrs of ownership/modding) for some recent head work
bought tomei cams & springs last june ($ to $ was good back then) and metal head gasget (Cometic brand). also ARP head bolts, and ported head work etc
ready for a GT3076 or a turbo such as yours all in good time, but got a highflow Slide turbo atm.
without catconverter was dyno'd at 226kw with mail-order ecu chip tune & safc/sitc.
IF you are going to pull the head down as part of your project then yeah budget it in, metal headgasket and some touchup of the ports etc.
depends on your mindset I guess........
your stock motor wont last long at 280 -300kw regardless of your tune start saving for rebuild
Obviouisly your wealth of experience speaking here, many people have run over 330rwkw for extended periods. Its all in the components being used, and the quality of the fuel/tune.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
