  • Replies 49
with aftermarket gauges, what should it normally read?
need to work out wether my sensor's farked...
I assume your asking for temp? If you have a Power FC + commander you can compare to the stock one.
Usually around 70-80degrees which is under halfway on the factory gauge @70degrees celcius...
A lot of other people run 80-90 degrees which is probably half way or past half way on the standard gauge, which I hardly ever look at so I'm just guessing here :(
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4420817
thanks
Hi there
160~180 deg F is about ballpark for lite use. (160~180)-32*(5/9) for deg C................. (degC*9/5)+32= Deg F or yoostabe, back in the bad old days.
You need a known good sensor to isolate source of error.
Find/steal/borrow known good replacement sensor & place (whilst still connected to your wiring harness, ignition on~ might need extension lead knockup) in cup of ice cubes floating in water, 60/40 mix, for 0~4 degC check of gauge, place in cup of boiling water for 95~100deg C. or there abouts. If ya want to get serious place a thermometer in reference liquid.
Alternatively you could plug your display into a mate's motor/temp sensor arrangement & verify your gauges.
Cheers GW
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4420831
My defi reads, 85 or so on regular driving and just above 90 on hard driving. Lcimate will play a big factor as well and also what coolant you're running, I run Texaco extended life and I am thinking about switching to Red Line Water Wetter.
Edited by TriniGT
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4423167
Stock thermostat is 76.5C.
Normal Operating temperature in the region of 82C.
Boiling point of most systems, 110-115C.
Stock dash temp. gauge is useless, half way (few mm either side) ranges from ~60C - ~95C, you won't notice it moving until you've already hit 100C.
Just below the top of the gauge for me is 104C (only seen that high once after a few big burnouts).
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4423612
85 - 95 for me up here in sunny north qld
where its hot all the time
Yeah mines about the same Pedro, microtech hand controller displays about 85-90. I've seen it over 90 a couple of times when giving it a bit during the day.
Gotta love our heat lol.
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4424350
Man i've got it good, runs about 75-80 depending on weather and up to 85 with hard driving in brisbane in summer.
I don't have air con though so that helps get some more air into the radiator.
Interesting :P I am removing my aircon condenser and receiver/dryer soon and putting a pair of thermos where they used to be along with some splitters/guides
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426396
i Dont think the water wetter is such a good idea in an rb. It does not stop rusting of the block and eats away the water jackets over time...... Cost me a whole Fuc&in engine!!!
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426515
Use it as an additive on the street, running it pure with just water would only be recommended for track use.
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426648
the standard ecu and powerfc keep the timing a little retarded and richen it up a little until water temp is 80deg or higher
half way on the stock guage should be 80deg
interesting. myne usually sits at 75-77 and only ever goes higher if thrashing it on a hot day (highest its ever hit is 81). got a pfc and i doubt it would have been over 80 when it was tuned, might explain a few things
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426864
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
