havnt posted in here for a while
how hard can it be to sell a hr30 2 door in very good condition minus driveline
id let it go for 1200
thats cheap, but thats life too
Tom
You should be able to get $1200 for it easy! As long as the inside's in good nick,as that's the most important bit,I reckon.
  • Replies 2k
Yep engine brace would be a good idea as well!! Just checked R30.co.jp and there is some interesting stuff on there in wouldn't mind! Like i said all depends on what sorta $$ we are looking at for it all!!
interior isnt brilliant, but the cage makes up for that
roof lining is like new
dash is 90%
carpet is 80%
seats are a little worse for wear.
$1200 is pretty cheap for your car though Tom, it would cost more then that just to respray the whole car!! Have u advertised it a whole heap?????
havnt really advertised it as im not really happy about selling
its in the for sale section
respray cost me close to that
but i need the coin
oh well
put it like this
add freight of 600 odd
for less then 2k you have an immaculate rolling hr30 shell with new paint
chasis is straight as too.
JENESIS PARTS
Due to the conversion cost of our dollar to the yen and considering Japanese freight/postage is about the dearest about, I believe all the engineering parts can be made here cheaper than they can be sourced from Jenesis.
The 2 door roll bar, I had a quote last month for just under $400.00 for it made from Chrome-molly tube. The front & rear strut braces & floor brace could be made here cheaper. The semi rigid sway bar mounts I am making here out of ROSE joints, cheaper. The adjustable and stronger caster bars I have sourced locally, cheaper than from Jenesis.
They really haven't got anything new, that hasn't been done here before, get onto your local rally guys that have worked with daddo 1600's and a lot of these parts are interchangeable from them.
Don't be SUCKED in by URATHANE BUSHES, they all aren't the best. The pivot points should be left rubber and others like rear cross member bushes and Diff support, caster bar bushes can be urathane.
People like Pedders recommend urathane cause they buy them for $1.00 and sell them for $20, where as rubber might cost them $14/15 and they sell for $20.
Body parts ... Side steps, badges, 260K speedo etc, could be a good thing, particularly if they CAN NOT be sourced or made here.
I am trying to source all of the engineering parts here, before I think about paying for the Jenesis parts. Go out and ask your engineering shops, take the pics off the site and ask, you might be surprised what you find.
My coil over springs are made to Jenesis specs, but made locally by ALLSPRINGS at Liverpool NSW for $115.00 pair. Jenesis spec F & R sway bars I have had made here for under $300.00 each, complete with urathane bushes. It was Jenesis where I found the BNR32 GTR front brake conversion, and that can be done here cheaper than Jenesis parts only price.
Just have to get off your butt and go looking.
Teflon lined, s/s braided street legal brake lines for $99.00 pair, made to order.
are the RS badges on the front LH + RH guards just stuck on there?? or do they have little pins on the back which are fixed into the guards?? just wanting to know as one of mine is cracked, so I will take them off and replace them with GT badges off a R33. I did want to keep it original, but $70 each badge is a bit steep I think!
hm so would that floor brace thing work well or would a rear strut brace do the same thing? i have a front one but wouldnt mind rear too if i can get it made up over here for cheap.
engine damper would be cool though coz my engine wobbles a bit, would be nice to get a damper for it. if they could be had around $250 or less id probly be interested.
boj01,
The R/S badges have 2 vertical pins, primarily as locator pins as they are held on by the usuall black double sided tape, and I would be surprised if the R32 & 33 badges would cover.
Where you get $70.00 each for new badges?
[ant]
Regarding the braces, I am putting in both. Making mine out of chrome-molly for strength & weight, but should be able to get them made from steel & powder coat cheap enough. Go and talk to your fabrication shops, sheet metal workers, light engineering etc.
And the damper! go talk to your local bike shop, motor bike shocks are available in a large range of lengths and compression/extension options. I found a Spax model that would do the job admirably, I think it comes off a 50 or similar for my RB.
Ok. A mate pointed out to me that my tail lights werent working last nite, so I checked all the fuses and found nothing (what a prick to check as I cant read Japanese and had to check all 20 of them). Checked the connections in the boot and a plug had disconnected itself so I connected it again and now the tail lights work, but not my brake lights! Any suggestions???
[Ghostrider] - I found that these are available through Hornsby Nissan a while back, do you think $70 is cheap or expensive??
If we can get a hook into Jenesis, there's are about $35.00 + frt/postage.
I would think $70.00 is a bit rich.
And I would wait a while to see if we can get something going with Option 1 Garages in Brisbane to get into Jenesis.
Re your brakes: Globes more than likely problem, but check brake light switch on pedal arm, but globes would be my choice. Get some quality ones, Phillips, Tungsram, or Narva PREMIUM, don't buy the shit at a garage.
Anyone know exactly what the 3 slat grilles are from?
Are they Jap only or would I be likely to find one in a wreckers here?
The 3 slat grille came in series 1, 81/82 Aussie Delivered POVERTY PACKS, sedans.
It was Ti sedans & hatchbacks that had the weave/milk crate/honeycombe effect between the slats.
And a 3 slat grille should be in some wrecking yards, but WHY???? would you want one, they look like sh!t. I got one here with TRUST on the middle slat, that must be worth a motsa eh!!! lol :(
does anyone have a 81/82 poverty pack r30 i mean the N/A version L24??
front strutbraces can be had from Whiteline, there is pleanty of places around that can make cages etc, a place in Hobart makes CAMS approved cages suitable for Targa Tas that can be removed and you wouldn't even notice it had a cage in it
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
