  • Replies 2k
I am led to believe the Grey one in HPI #43 is FOR SALE. Check it out on pages 91 & 92
Contact Ben ELLIS from HPI Magazine on (02) 9741 3858
I have seen the car in the flesh and it's a minty condition car, VERY stock, but excellent condition and asking $8-10000.00 with 85K on the clock.
You would be hard pressed to find a better example and it's registered in NSW.
Check it out!
stu_r30 - That'd be benny's DR30 in the For Sale section. You're correct, it is a very nice car, gotta love that colour too!
Ghostrider - I believe that grey DR30 in HPI #43 has now been sold for $9,900, check the Autostyle website:
http://www.autostyle.com.au/cars_engine.asp
If I'm not mistaken, it's the third last Nissan in the list.
just wondering what either a turbo set up or the complete engine would be worth....im putting an l24e into my 1.2L hilux(1974)
gunna haul a55, but would haul more a55 with a turbo.
Option 1 Garage has an L20ET turbo & manifold on their web site.
But needed further is wiring, ECU, etc to make it all work.
More boost can be obtained using an FJ20DET turbo assembly.
Crimmo is what his face (can't remember his name) making all that stuff up for u?? Sounds like its goin to be a bloody tough car when ur finished with it!!
T shirts im up for one as well!! As far as arty designy stuff goes though im a shocker so no design's from this side of the fence!!
How would i go about doing this to my headlights?
thought you had a pic of a BMW for a second, if you want to do that try getting it air brushed on?? several coats as the light will shine through! that way paint stripper will fix it later..
theres a nice dr in the for sale section - 8g's i think, looks nice
and as for the shirt, matt, you've outdone yourself with that design...
seriously, would look pretty good and as others have sed, the r and 30 should be together  :D
car'nt take credit where credits not due, that design is ghostriders, but if you want i'll get a mate to draw up some of the ideas. this is some of his work..that shot is from the need for speed PC game and yes it is a r31 and r30 racing..mate drew the r31..his on line name is 75 degrees sideways..trying to get him to buy the purple dr benneys got forsale??
ive seen that thing done to lights before in some pictures when hunting around the net. they do it on that car with plastic over the lights im pretty sure, as the pic i saw was closer up than that one. not too sure how they do it exactly but its definately a proper plastic surround that you can get, probably coz some pple dont like the plain square lights :D
id say the best way to do it would be with stick on stuff similar to contact, you know like people use to stick on their headlights to do like 'eyelids' n stuff. i dunno where u get that from, car sticker places or watever i guess. just cut it to size and stick it on. then just peel it off and use some stuff to get rid of the sticky residue when ur done.
I would say its a different approach altogether.
remove the glass (by the way how do you do that, im trying to do that now), remove lenses and replace with a round sealed beam and then have some type of cover made to go over it. well thats how i picture it, and yes i though of bmw headlights when i thought that idea up!
somehow i wouldn't go to that degree
when i first got my car it had no headlights and i was thinking of getting ones from a s13 silvia that have that kind of look, i think they have 3 lights not 2 though?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
