  • Replies 2k
A set of MR30 panels and lights will cost you $200 and get it on the road, and will only take you an hour to swap over when you get the Tekamon stuff
Hows about no?? It left the road as a tekaman and its coming back as one as well!! Besides, im to lazy to swap panels around again, i just want to do it once and thats it!!
Besides that, the longer its off the road for, the more stuff that is getting bought for it!! My cooler is getting modified in the next week or 2 and hopefully i'll have that wastegate and manifold in the next few weeks as well!! Should be some fun soon :)
All thats different is the bonnet, lights, grille and filler panel, and the bonnet catch support
I'll continue to enjoy driving mine :rofl:
I do have a Tekamon bonnet, lights, filler panel spare atm, plus a set of guards
Hey, if you have the takemon bits spare, would you be interested in selling them?
I have an MR30, and want a takemon front end. are the gaurds any diferent to MR30?
I'll continue to enjoy driving mine :P
Wouldn't wanna lend me some stuff till i get mine would ya :) carn i know ya do :P
TEKAMON Vs STANDARD Fronts
For those that are wanting a performance vehicle?
The DRAG co efficients of both fronts are Tekamon/Iron Mask 0.37 yet the standard front with large head lights etc has 0.46.
Some perspective is the Z32 300ZX has a drag co efficient of 0.32.
The lower the number the less air drag.
Interesting,but also for consideration for those wanting a performance vehicle would be air flow to intercooler,radiator,oil cooler,etc....Surley the early style front would be better in that regard?
BTW,the mighty HR31 would have to have a pretty good drag c/e ,having flush fitting side glass,etc? Wouldn't have any figures on them would you?
I could... just dont put em through a shop :D
One guard is white and one guard is sorta gold though
Guards im not interested, neither a bumper, just headlights, filler panel and type c spoiler..im meant to have some coming last i heard they were being sent last week but i haven't heard anything since then*shrugs* who knows..If your willing to lend them rad, speed the process up, if not sall cool cool
There is an excellent article in Autospeed this issue about airflow through the coolers and believe it or not, it has nearly SFA to do with the size of the front opening (grille area) that determins the amount of airflow.
It has everything to do with the amount of pressure in the engine bay and how successfully you disperse it.
Lift the back of the bonnet about a cm and you will be surprised how much difference is in the airflow.
I am getting a couple of the gauges that measure the pressures and do the tests myself and then I will let everyone know the outcome.
DRAG, has an effect at 1 kph, but a much greater effect at over 100.
Take these "shopping trolley handles" that are on Hyundai Excel's for instance, a mate took the one off his misses's car and got an improvemrnt in fuel economy of over 5% and it has never been over 80 kph in it's life.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
