ok if anyone is interested i have Z32/R32 brakes im thinkin of selling, probably pointless trying cos u guys could get them cheaper than the inclusion of freight.
but they are 280x32?? and the caliper is alloy not steel. they have had the Nissan logo ground off to slightly improve the clearance problem.
i am thinking of going the R32 GTR/R33 GTSt option.
ps CA18 250mm rotors DO NOT PULL UP A RB25DET powered silvia from 80kmh very well at all!!!!
  • Replies 2k
oh and by the way my MR30 has had the brakes upgraded on the rear for what i believe is a hatch, had the cross member swap etc. makes a huge difference over a drum rear end so i think they are good enough
would'nt it just be a stright swap for the IRS system?
anyone know of anyone looking to buy a unfinished project car, its red and black comes with a working installed rb20det, low kms, new seats, big fmic, auto meter gauges new running gear and suspension...PM me... :D
Hey Guys,
Just an update, got the front and rear pad numbers, can get pads no worries, can hopefully get the discs machined.
HOWEVER...the handbrake cable is seized solid, and new ones are $121.75 for the left and $108.10 for the right. Has anyone here got a handbrake cable that isn't ****ed that isn't on a car that they wish to sell or something?
oh and would you believe that the guy from spare parts in Nissan didn't know what an FJ20 is?!!!!
anyone know of anyone looking to buy  a unfinished project car, its red and black comes with a working installed rb20det, low kms, new seats, big fmic, auto meter gauges new running gear and suspension...PM me... :cheers:
What's the go Matt?
Not going to finish your project?????
What happened to the re finance etc, etc.
D
What's the go Matt?
D
oh thats still going ahead, its just i have the found a new toy today and it involves letters like gts-x rb and 26dett nismo 2 seats and a roll cage :headspin:
hehe is that the 17k one? that looks cool. lucky bugger. i wouldnt mind RB26'ing my DR30 one day! if i get a proper job and lots of money ill see what happens! haha
stopped into the suspension joint today to check out my front suspension coz that knocking was really starting to shit me ... needs
Lower Control Arm bushes
Radius Rod bushes
Idler Arm bushes
so im getting all those replaced with polyurethane ones, costing $500.
but also noticed my steering box is leaking ... needs a rebuild and shit which is $500 also :wave: bugger. hhaha. looks like intercooler is back another month or two again! need that tax return!!
*continues filling out the sign-up form for his Virgin Credit Card* >:cheers:
rsx84 - yeh a mate of mine posted it on a chat room and i had a good look at all the pics n info. be a pretty damn nice car :cheers: so is it definately yours then ?
Neo - haha its hard to compare i guess coz true, an RB26 is like 6k + install and stuff ... throw 6k at the FJ and itll probably be indestructable and bloody move too .. mind you it'll probably use more fuel and be less everyday-driver friendly too ... but really all i want is 350rwhp and a good all round package .. no need for gimmicky tt setups and stuff i spose! haha
always remember the silver Zeni Tan DR30 that had the 26 in it up for auction a while ago on Prestige i think it was ... wasnt that much either but i cant remember exactly how much. low teens i think.
mind u that 31 looks almost as cool ... but id **** off that GTS-R wing ... if it was a real gts-r i see the sentimental value of it, buit otherwise its just bloody ugly i reckon!! haha
this is what i'm willing to give my r30 for!! ANT did you read the list of work done  :headspin: what a weapon a rb26dett dr30 would be!!!! :wassup:
Is that what's turning you on?????
There a BRICK! 1300+ kg, but your choice.
Bet it won't be as quick as mine, RB26DETT and all it's mods.
The HR30 will reign supreme.
']hehe is that the 17k one? that looks cool. lucky bugger. i wouldnt mind RB26'ing my DR30 one day! if i get a proper job and lots of money ill see what happens! haha
Radius Rod bushes
Idler Arm bushes
but also noticed my steering box is leaking ... needs a rebuild and shit which is $500 also ;) bugger. hhaha. looks like intercooler is back another month or two again! need that tax return!!
Don't replace the lower control arm bushes with anything but RUBBER! keep all PIVOT points RUBBER, the others can be Urethane, but don't get sucked in to believing it's the be all end all, talk to some rally guys and they will tell you the same.
They promote Urethane because of the HUGE profit margin they get from it.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
