  • Replies 55
Ironically, none of the F trucks getting around here are cowboy rigs, most have a nice paintjob (for some reason there's 5 or 6 purple and pink ones :S) it's all clapped out WB shitheaps or the new trend of 'cowboying' up a late 90s model Rodeo or Courier.
I've also seen an XF ute with one of those flaps on the end of the exhaust which shuts unless under load, like some trucks have, and I've seen the driver deliberately ramming trolleys in it in carparks late at night, must be practicing for running down roos or something :mad:
I saw a sticker on the back of one of these Muppets Utes the other day....it read, "Real Aussies drive Holden Utes"
The sticker was on the back of a Rodeo.... ;)
Last time I checked, Rodeos were made by Holden! They dont just make bommodores y'know :P
A young dude (P-Plater) who works with me has his Rodeo tricked out with 'Stacks'. He said it cost him just under 2 grand to have them installed. I lol'd.
Ill get a pic next time I see it.
lol sick burn.
I've seen a ~20 year old single cab Rodeo mocked up to look like a Prime mover, complete with lights, perspex bug protector over the bonnet, lights, rear view mirrors, stacks, flaps and a turntable on the tray! Wish i had a pic lol. The owner apparently went into a local truck place to see if he could get Jake brakes fitted as well roflmao.
I have also seen a Datsun 1200 ute done up as a B&S rig, I felt sorry for a decent old ute being tarted up like a tawdry middle aged hooker :)
But they have Holden badges yes or no?
Not all Rodeos are Isuzus.
Holden Rodeos are sold by Holden = General Motors (GM) subsidiary company
The Rodeo was built by Isuzu between 1980 and 2008, being replaced by the Holden Colorado.
Other GM Subsidiary Companies are:
GM Isuzu (Japan)
GM Opel (Europe)
GM Vauxhall (England)
All under the GM Umbrella
I think that's how it works..?
Last time I checked, Rodeos were made by Holden! They dont just make bommodores y'know :blink:
Holden dont make anything on there own, they use some else's engine, gear box, diff and styling, now take a look at ford, the 6cyl engine is all aussie, the chassis is all aussie and used as a platform for other models and the body design is all aussie, the v8's are yank but who cares about them anyway xr6t FTW.
probly why Holden build a better car :P
Holden started life as coach builders re-bodying other peoples product, why change after all these years?
They do make a good Daewoo's though, i'll give them that.
Did I just get that arse about?
GM(H)<<< generic marketing.
Even the torana was Albanian..Jk's, It started out as a vauxhall of course.
commo was german
looked shitloads better
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
