hey im about to buy some aftermarket gauges for my r34gtt 4 gauges in total now which gauges are the most important/necessary ones for a good setup with up 290rwkw aftermarket turbo and computer efcourse!
this far ive got in mind oil temp, water temp, exhaust temp, boost.
dont hesitate to tell me what you think and why.
thanks..
Edited by allthewaytotheskyline
What you need depends on your set up, me personally i'm looking at oil press, oil temp, water temp and air/fuel, all with warning lights, i don't need a boost gauge as i have a electronic boost controller (PRofec B-spec 2) which has a reading which i never look at anyway (if I'm on boost I'm just holding on and watching where I'm going), I'm just looking for gauges that when i have a quick glance at them if the red light comes on i know to back off because there's something wrong.
none of these are important for a mild street car
the std gauges are fine
whats more important is
how its tuned
watching when it knocks
how your boost controller is setup
these by far outweighs the cost and purpose of having guages everywhere
your boost controller should have a safety cut, ie it should back off if boost flies past the target pressure, ie something fails, it shouldnt run unlimited boost
when the engine is knocking you should have a warning or alarm or some form of protection
it should be tuned so that you get good economy, it has aggressive timing (within knock limits) and is setup for average conditions
Oil temp, last Saturday driving in 46'C day [day of bushfires] my oil went to 108"C, I hated it, but slowed down and it settled on 97'C, so very necessary.
Oil pressure normally is 3.5 at 3000rpm, on this day it was more like 3.0, but I was semi reassured that at least I had useable pressure.
Exhaust temp, cos you can see how hard your turbo side is working and also know when you can turn your ignition off [so you don't always need to use your turbo timer or wait around unlit 2 minutes are up etc]
Water temp, I've never really needed an accurate figure, as long as its not increasing or overheating, then its OK, so you only need an indicator, not a real time measure.
You will drive to suit the conditions and the readings of the above three, the others are handy, but not necessarily condition dependant, more tune dependant. And if you using a PFC [and some other ECU's] then you will get a reading from them during or at the end of the trip anyway.
But I don't do any track days, mainly highway/main road only, so your use could change this.
oil/boost press
water/oil temp
I wouldnt do without my wideband afr but as above - an engine can knock even when running rich so its not foolproof.
Edited by DCIEVE
even 108 is probably fine for oil temp
yeah, could be, but who wants to get stuck on the Hume highway on a 46'C day.......lol
On a normal 30'C or less day, it sits on around 85'C, so a 20'C increase is time for some caution in my books, to be sure to be sure!
On another note, it must have frustrated the hell out of the highway patrol car that snuck out and followed me for approx. 20km into Holbrook and I wasn't speeding or hooning at all - too hot.
ok im beggining to sway to these gauges oil pressure, oil temp, water temp, exhaust temp as my electronic boost controller reads/displays boost and has a auto over boost cut limiter.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
