incorrect. i would suggest looking closely at the maxima unit from a wreck.
it consists of:
steering wheel with switch
clockspring
brake and cruise lockout switches
lockout relay
electronic control unit
vacuum pump
vac servo and cable.
the latter comes in various lengths so find one that suits your car and use that.
in my case with a rb20 it was taken from a U13 bluebird.
if you do grab a mid late 90s unit get the matching electronics from the same car. the vac pump and servo you can mix and match to suit
your position in the engine bay providing you get the cable and thread length correct.
  • 4 weeks later...
True, I have been there with the old vacuum versions. A common problem with both though for me I think might be fitting the actuator somewhere in amongst all the gear in the 4WD stagea's engine bay... but will give it a shot.
I'm keen to see how this all turns out as I've been missing the cruise control from my old Statesman. I don't suppose auto and manual would be any different? Please keep updating. And a price list of all the parts would be lovely if you find them and don't mind.
Cheers.
mine sits one the firewall.
middle top of image.
pump you can put anywhere. mine is actually in the stock spot in front of the strut tower drivers side.
I have since revised that bracket to a early 90s maxima one. it sits on the strut now.
costs - not really relevant. all of it will be secondhand from wreckers.
auto and manual ARE different electrically. if you are going to pull one from a wreck make sure you grab everything attached to it.
Thanks Chris. I was going to ask where to fit the actuator in the engine bay of an RS4 C34... it's pretty packed in there :(
I think I will have to mount mine in the cabin (under the dash). The only thing which concerns me is I don't know how noisy the unit will be when it's operating.
Also, does anybody know if there is a cruise light in the dash?
Edited by DaveB
it will fit out side. give me a bit to do scotts one and I will pop a few images up. no light in the dash going to use two LEDs or if I can find a spare light socket in the dash I will make something fit.
Awesome, thanks :-)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
