As i'm sure you're all aware, we are in for a bit of shopping spree on behalf of the government.
Being the enthusiasts we are, it is probably safe to say a lot of us will spend this money on our cars.
My R33 currently has a 3 inch turbo back exhaust, front mount intercooler, high-flow panel filter and has been boosted to 12 pounds. It has been dyno'd as having 160 rwkw (A little disappointing yes- needs o2 sensor desperately). Everything else is stock.
My question to you is:
What would be the best way for me to spend this $900 bonus on the car? The aim is to increase performance as much as possibile.
Let the ideas flow!
https://www.sau.com.au/forums/topic/260822-kevin-rudds-stimulus-package/
  • Replies 84
the liability to pay tax on your earnings rests with you mate as you have to declare it in your income tax return. If you choose to work for cash (lucky you if you can I am spewing about the ludicrous amount of tax I will pay this year) then you already have an advantaged over not giving 30, 40, 45% to the taxman, so you cannot be too aggrieved about not getting a hand out.
On the other hand, I am f**king pissed, I have paid over $60k in tax this year so far and I aint getting shit, who the f**k paid for all these handouts in the first place....... its bullshit
I have one of the $22 boost controllers that were the talk of the town on here a while ago. It does a pretty decent job of keeping boost. But I sometimes find the acceleration is not that smooth, so perhaps a tune would be in order?
I'd be pretty happy if I paid 60k in tax, surely it would mean i'm doing ok. Not taking the piss mate, just being honest with you.
Injectors would break the 900 easy, since your only putting out 160rwkw your injectors should be ok for an e85 tune, do that an you'd still probably have 500 left!! New fuel pump as well, 300 still left, spend that on noodles for the next 3 months for the next round of upgrades
I thought it was only for families, not single people.
This government going to ruin the country, they should be saving the money and use it on building pipelines for water from the north or other infrastructure, that would create jobs and help with the droughts and irrigation problems that the growers are facing, now the country will be going broke-jobless-and starving, families could use it but giving it to everyone is playing Russian roulette with the future, wasting our taxes on hand outs to everyone.
C'mon man, if I was paying more tax than the average person's annual full-time salary I wouldn't be complaining. Tax rates are lower than what they used to be. I ain't happy to be supporting dole-bludgers through c'link, but it's the price we pay to live in this country.
PowerFC is what you need.
easy
Status Tuning remap. Cheaper than PowerFC and Trent will make sure you have a top tune. Try buying a Powerfc, getting it installed, and tuning it for the stimulus cost.
That will be most of the $900, then maybe you can just ask him what you should spend with the rest.
And in addition, you're spending it on a local service, which is the best way for the money to be spent. If the daughterboards came from oz it would be ever better!
but yes, cash handouts are f*cking useless - but i'm going to try and make mine as productive as possible
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
