  • 4 years later...
Bringing a thread back from the dead
I recently got my car back on the road and have a 1000hp ati balancer on it
Cars only making 400hp
My ac belt has came off twice in two days first time completely gone and damaged power steering belt
2nd time belt came off still in one piece but ended up damaging my brand new radiator
Just normal driving on the street with your random squirts here and there and a few 8k clutch dumps to test out the new diffs
Has any one found a solution for this as I would like to keep my air con for summer
Never had this issue. I also run the 1000hp ATI balancer and have done for many years
I'd suggest looking elsewhere. Fitting/adjustment or another issue.
(435hp)
Edited by Sinista32
How about selling the damper to someone with heaps more power than you and then you could buy a 500hp damper .
just curious (I dont have an ATI damper)
IF the proper belt is used and tensioned properly, together with a good condition ac pulley, how would the belt come off?
the grooves in the belt/pulley plus the lip on the pulley will hold the belt in place no?
unless the belt was loose/worn...or the damper was vibrating so much until the belt could slip over the grooves (which is highly impossible cos that means your engine would have been destroyed)
I would check the belt tension and make sure the ac is properly tightened :)
Defiantly have the right balancer
Why would I sell it and get the 500hp one?
I been doing some research and ati them self's don't recommend high rpm with the ac belt on I think this is due to being smaller then standard and the pully is spinning alot faster
So I might leave it off for now and when it starts getting hot I'll put it back on and just take it easy
Everything is tensioned right and correct belts are being used
Ditch the A/C prob solved.. I also have a ATI 1000hp balancer and im getting rid of my A/C as i wont be needing it anymore. If the car is going to be used purely for weekends im pretty sure you can survive with out A/C ?
Edited by Tyranus
Yeah that's what I'm going to do now I was trying to build a nice comfortable street car but who am I kidding I have front and rear lsds and a twin plate clutch
I'll keep the ac in for now and when it gets hot I'll put the belt back on
Because you said this:
2nd time belt came off still in one piece but ended up damaging my brand new radiator Has any one found a solution for this as I would like to keep my air con for summer
  • 1 year later...
Bumping an old thread
I got an ATI 1000hp balancer on my hks 2.8 stroker, had the ac belt come off on the Dyno, put a new belt on and 2 squirts later on the street found my ac belt has flipped upside down on the pulleys
Anyone know why? I just cut it off for now as its winter but ultimately I do want a working ac system and that I can drive the car without it always damaging belts
Ac tensioner has a new bearing
They warn you in the instructions about the a/c being overdriven and the belt should be removed when racing, not sure if that has anything to do with it though
Is that in turning on the AC or not? I can get any firm clarification. Would it matter if the AC was not engaged? Would it be the same as a stock balancer at 10,000 RPM?
I have herd you need to remove it for racing but my mate has same engine and balancer and it revs to the moon and always hitting limiter and never has issues so dunno why mine would through a belt after Afew squirts
Annoying
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
