Hoping mine doesn't get same issues with the .63 rear, however should be easier to hold 20psi externally gated yeah?
My cooler is 510x250x70 , tube and fin, which is worrying me a bit, however can't go any wider due to auto spoiler motors for the flip down lip on the 31. Could go to a 510x300x100 probably max.
^The only thing I'd be worried about is heat soak, not boost control.
what power are rou aiming for? 510x300x100 is a fair sized cooler. See how your current cooler goes first though as its far from tiny tiny. Depends what your goals are and uses for the car. Sorry if you mentioned this on the previous page.
Aiming for 290-300rwkw on 98 with the ATR43SS2 op6 version, which tao has explained has a larger rear wheel to suit the .63 rear housing. Yeah i don't think it will be an issue and its piped very direct, not a return flow or anything, just all these stories in this thread are making me worried about it haha. i hope it doesnt drop alot of pressure across core.
  • Like 1
hey stao, looking for a turbo eqivilient to a t28bb/ but no bigger than a gt2860rs for a sr20. would i be right thinking it would be a ss1pu .64 and looking back through results do you have any for a fairly standard non cammed non vct s13 with standard mods 3" intake exhaust z32 550cc etc?
The ATR28SS15 would be a perfect turbo for your application. I didn't look into some thing even smaller as it doesn't make that much of a difference in response but did loses quite a lot of power.
I've handed drawings of two more sets wheels to be engineered for the GTR. for main time, I've picked up a members R34. Its got 170,000KMs on the clock, average condition, with heaps of ice and minor engine mods done by a 20 year enthusiastic. probably due to the mileage, this engine feels pretty rough compare to my other two skylines. This might be affecting performance on the dyno.
Condition of this car probably represents the majority of R34s on roads today. I will be installing commonly seen mods including a Blitz return flows cooler kit. the goal would be around the 330rwkws mark on Pump fuel, internally gated bolton. Will upload dates as project moves along.
  • Like 8
Some results sent in. This is a ATR45 SAT version on an Rb25det Neo motored Stagea, Dyno dynamic roller dyno shoot out mod. Final result of 400awkws (red) on a 36 degrees day, against a turbocharger that was previously installed.
Unopoened engine, factory cams and cam gears. Usual mods and E85 fuel.
Good example of an externally gated setup out of factory exhaust manifold.
I think you will need to preload the actuator alot more then where it currently is. Was this SS2 built with a black .70 comp housing or a smaller .60 comp housing?
make no differences. the one with .60 housing is easier to install, black housings with 4 inche inlets are .70. Preload your actuator by a further 5mms, go for a drive and keep an eye on the boost gauge to see if that have made any changes.
  • Like 1
Quick question, I've still got the ATR43SS2 in the car and it's been going great. I've noticed that it sounds louder on boost after a recent track day, is this any cause for concern? It still boosts up to 20psi like before.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
