R31Nismoid Posted April 8, 2009 Share Posted April 8, 2009 i guess i do. im just going by that chart, that says the G2 is rated for 450hp (not sure if its @crank or @wheels) The chart say 450hp - that is not 450rwhp. 450hp is @ the motor... ALL turbos are rated in such a manner Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4524063 Share on other sites More sharing options...
ARETHT3 Posted April 10, 2009 Share Posted April 10, 2009 Group Buy anyone???? Can u do any deal for a group buy HyperGear Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4527769 Share on other sites More sharing options...
hypergear Posted April 10, 2009 Author Share Posted April 10, 2009 Should be able to give a 7% discount for a minimum of 10 orders. Thats about the best We can do to have them made. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4527795 Share on other sites More sharing options...
geraus Posted April 10, 2009 Share Posted April 10, 2009 Hello Tao , How are you.. do you make any rear housings for my turbo? like bigger ones? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4527800 Share on other sites More sharing options...
SS8_Gohan Posted April 10, 2009 Share Posted April 10, 2009 you'd probably have to find an old OP6/VG30 rear housing Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4527888 Share on other sites More sharing options...
hypergear Posted April 10, 2009 Author Share Posted April 10, 2009 You can check for a OP6 rear. We will have the the bigger rears soon. The engineering place just take their time doing it. Hopefully be available in Mid May. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4528012 Share on other sites More sharing options...
Keeffy Posted April 12, 2009 Share Posted April 12, 2009 Im def considering grabbing up one of these, specialy if we get a group buy going on. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4530302 Share on other sites More sharing options...
geraus Posted April 13, 2009 Share Posted April 13, 2009 i will be the first one to buy the BIG REAR Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4531828 Share on other sites More sharing options...
Paradis v.1 Posted April 13, 2009 Share Posted April 13, 2009 sent an email to your site. thanks Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4531833 Share on other sites More sharing options...
RBceffy25 Posted April 17, 2009 Share Posted April 17, 2009 Hello Stao! I have a vg30det turbo 4V54 front with OP6 rear sitting in the shed. I would like to no how much for a high flow? it is for for my RB25DET Cefiro street car so i'm trying to keep resonse in mind while still achieving as much power as possible. Having said that, wats gonna be better ball or bush bearing? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4540708 Share on other sites More sharing options...
hypergear Posted April 17, 2009 Author Share Posted April 17, 2009 (edited) The high flow will cost $800 plus $80 oil feeding line. We will be using ATR28G3's profile which should get you around 260~270rwkws (OP6 rear) with supporting mods at peak and not too bad down low either. Edited April 17, 2009 by hypergear Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4540757 Share on other sites More sharing options...
simpletool Posted April 21, 2009 Share Posted April 21, 2009 With R33 stock housing its very close to its limit, maybe another 5~10 kws once leak fixed.With RB20 turbo's high flow I'm not too sure as I haven't had one dynoed yet. I guess its probably archive close to 230rwkws. Wheel size wise this is using the a 71mm comp with 65mm turbine. With Garrett GT2871Rs its running the same size comp wheel but 53mm turbine. I'm guessing you mean 71mm comp with 56.5mm turbine. I guess you use this on the larger rear housings as the stock R33 rear housing isn't large enough? Would the larger rear housing turbo be suitable for a remapped ECU R33 car if only running 9psi? (currently runs fine on 10psi stock turbo) As a replacement for stock turbo until I get off my arse and get injectors, AFM and powerFC? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4547113 Share on other sites More sharing options...
Keeffy Posted April 21, 2009 Share Posted April 21, 2009 Anyone want to organise a group buy for the big rears Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4547258 Share on other sites More sharing options...
lorenzo1985 Posted April 21, 2009 Share Posted April 21, 2009 heyyy wat sort of power will i be lookin out with an rb20det Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4547599 Share on other sites More sharing options...
hypergear Posted April 21, 2009 Author Share Posted April 21, 2009 (edited) We do use 65mm Turbine. Need some thing to flow as possible in a small turbine housing. If you can get a OP6 turbine housing we can use ATR28G3 CHRA with 76mm comp wheel. That will be able to get you over 250rwkws. You can drive it on low boost no problem, as for the best results get it dyno tunned with Power FC and supporting mods. As for RB20 using ATR28G2 hi flow you can probably get some where between 200 to 230rwkws. Edited April 21, 2009 by hypergear Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4548048 Share on other sites More sharing options...
hypergear Posted April 21, 2009 Author Share Posted April 21, 2009 (edited) Any way adding some photos of the OP6 reared hi flows. This is a complete ATR28G3 high flowed into a OP6 Rear housing (note the mark on the housing) GT2871RS CHRA high flowed into R34 OP6 Rear with stock comp housing: This is a Custom made GT3076RS in a .63 Rear internally gated setup bolton to stock Manifold Edited April 21, 2009 by hypergear Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4548077 Share on other sites More sharing options...
OVADRV Posted April 21, 2009 Share Posted April 21, 2009 Stoa have you got a workshop in in camberfield? if so whats the address? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4548187 Share on other sites More sharing options...
hypergear Posted April 22, 2009 Author Share Posted April 22, 2009 I've PMed you with our address. Thanks Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4549770 Share on other sites More sharing options...
simpletool Posted April 23, 2009 Share Posted April 23, 2009 (edited) Will the larger rear be 0.7 A/R with skyline bolt pattern? I want 230rwkw at about 1 bar or less, I'm thinking a 2871 would get there easier with the slightly larger housing. Is R33 rear housing 0.58 A/R? And where did these 0.7 A/R housings come from? Couldn't they have made them 0.82 or something to flow a bit more? Edited April 23, 2009 by simpletool Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4552468 Share on other sites More sharing options...
hypergear Posted April 23, 2009 Author Share Posted April 23, 2009 The larger rear would be a .63 rear with RB25's bolton pattern. If you perfer 230rwkws BB GT2871 CHRA should do it fine. You can get that with stock turbo's rear housing. Stock R33's rear is only .48 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/2/#findComment-4552491 Share on other sites More sharing options...
