Here are few more Photos of Powered Up high flowed R33 turbo with 2IU turbine housing:
Note the difference in volume of modifed turbine housing on the right:
Thats some cool modifications and porting to the housing.
Hi
Whats the response difference or lag difference between the G2 and the GT3040?
I have a R34 GTT Auto, a brought a GT3040(GT3082) with a .82 rear housing a while ago to put on. Now i think it might lag to much with the auto.
Am thinking of selling, to get the ATR43 G2 or get the original Skyline turbo high flowed.
PS. Only just found this forum topic and have just joined SAU
Hi there. If you are looks to make around 230rwkws with excellent street driving ability I can high flow your stock turbo to same spec as a 2530.
Hi
On GT3040, boost wouldnt come on at all under 3500 (which when driving normally is annoying) with G2 turbo comes on about 2700 (only couple of pounds which count when your trying to over take). Full boost 3500 rpm.
LAG:
On gt3040 i would have full boost at around 4500
G2 1st gear 4000, 2nd gear 3500, 3rd gear 3400 5th 3200 rpm.
My opinion:
I was supposed to go for G2 from the start, and mates talked me into getting 3040 instead (M I S T A K E). Unwanted attention, got put off the road. canary.
G2 is better or as good up to 5000RPM, after that not as good but very close to GT3040 IMO. Fully legal, i recommend G2.
do you guys do replacment for standard turbos on a r33 gtr? what specs are they and how much power would the rebuilt turbos make? also how much would they cost? sorry couldnt find anythin reading through the pages only found rb25 upgrades nothing for the rb26.
LAG:
My opinion:
Hi
Thanks for the info. I will look at selling the GT3082
With RB26 we normally high flow them to 2860RS spec. which works out to be the -9 configurations in your stock turbine and comp housings. they would be ok for up to 320rwkws before you need bigger turbine housings. Response wise they feels like the N1 steel wheel turbos. Not as responsive as the stock cermaic wheels.
Photos at:
http://www.digi-hardware.com/gtrturbos.htm
We can build custom .60 A/R comp and .64 / .86 turbine with OEM boltup pattern for those if required.
Hi
I will be looking at getting one in the future
What is the latest prices on the
Skyline ATR43 G2 0.63 turbo?
and
High Flow R34 G3 OP6?
thanks
Hi
and
thanks
ATR43G2 .63 with high pressure actautor and braided oil feeding line we can do for $1530.
To high flow your stock R34 turbo cost $960 including braided oil feeding line. high pressure actautor is additional at $150 each.
Photos at:
I'm curious as to whether you have done one of these custom turbo's for a GTR yet and if so any dyno graphs or similar or info :D
Have done few. Not as many as other turbos thou. Have also driven one. Un-tuned, car pulled hard after 4500RPM but have lost fairbit of response to stock ceramic turbos. its about 300RPM laggier then stock N1 turbos.
Sounds very interesting, what is the price on this for an R34 OP6 turbo?
Convert that into OP6 R34 turbo cost $1000 including braided oil feeding line and oil drain adaptor.
To do this we have to modify T28 bearing housing to suit a T3x pring turbine housing.
I was thinking if you could use the new VARA turbo's that your making in a GTR...maybe not :D
Probably not at this stage. They are too small to work with.
Standard from $800 + GST + oil line $80 = $960
Powered up high flow from $1100 + Oil line $80 + $150 High pressure actautor = $1310
This might be a silly question but is it possible to just replace the standard ceramic turbo wheel with a steel turbo wheel so that boost can be raised safely above 12psi? Do you offer a price for that? Would it still require a different oil line?
We actually build a brand new turbo core with bigger wheels, then machine your stock housings to suit it. We only use steel turbine wheels. So are you actually getting back a brand new turbo inside your factory housings.
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
