The actuator has the same spring as in the large can actuators. Unfortunately stock comp housing does not have the clearance to fit the large can housing. So I’ve pressed the same spring into a smaller actuation housing. The result would be identical.
With the waste gate controller. It can be loaded or adjusted to give effects or un-loaded to give no effect. It will still be working with a high pressure actuator.
You will likely to archive the highest exhaust manifolds pressure reading in 4th gear. Ie: Cars with smaller wastegate port or restricted dump pipe spikes the most in 4th and 5th gear.
Means if you can get boost curve to hold steady by pressure dispatching limitation in 4th / 5th then it will unlikely to spike during lower gears.
This method changes the traditional external dependent analog operation into limited / none dependency mechanical operation. The only car that has been on dyno with it is the 290rwkws PU high flowed unit. Unfortunately I wasn't present during time of the tune, plus turbine housing used on it was in .82 with GT35 spec turbine wheel. I've been informed by Nick that he did not experience boost drop at 19psi as you can see the power curve did not go flat or tip down towards red line.
Other thing mentioned is PU housings are equipped with 30mm internal gate with a large flap to total eliminate un-controlled boost spike. I believe the wastegate controller is the only solution in stabilizing boost control with internal wastegate setups.
Any way I'll be seeing Mark next weekend to check out his actuator and integrate the wastegate controller to his current turbo.
What psi spring is in there? 14psi? Surely its possible to get a higher psi spring
That depends on the size of the wastegating port and gate flap.
Force = Pressure x Area
So the bigger port and gate you have the greater force is required to keep it shut through the actuator or other means.
Stock housing's only got 24mm gate, ATR43 housing's fitted with a 30mm gate. So the actuation level varies with the same spring tension.
Overall smaller wastegates are more likely to gain overall control with an actuator only with smaller wheel combinations on smaller engines. Larger wheel combinations requires greater sized gate to eliminate uncontrolled boost spike but harder to gain overall control. Which is why waste gate controller was introduced.
So you are using the highest tension spring in the actuator available? I have heard of actuator springs up to 25psi, surely there is something stiffer out there that can be jammed into the small can actuator.
your big can actuator looks extactly like the std actuator... the small can actuator makes it look aftermarket and not stock at all... im tempted to modify the standard wastegate actuator bracket, so that the larger can (one that looks like standard size) can fit
I'm fitted my own AFM in between cooler piping today. Pretty easy:
You need 4 clamps, and 2x 3 to 2.5 inch reducers. (we can supply them for $50)
and a metal 3inch intake pipe made out of 40cm long 3inch aluminum pipe with a 45 degrees 3inch rubber hose:
I apologize if the heat wrap looks crap and funny. lol (found it pointless having a big cooler if air's picking up heat again through piping).
Also we can install a big 32mm disc and machine 30mm internal gates @ $100 for who ever wants to get it done.
Finally finished the install off my external gate ATR43 with a .63 rear housing and all I can say is wow >_<
After the first test run and it's making full boost at 4300 rpm (compared to 4500rpm with previous VG30 highflow) and the external gate sounds off it's tits :cool:
Can't wait to run it in and get it on the dyno for a re-tune.
Just to update I loaded it up in 4th and made full boost just a fraction after 4000rpm, so nearly 500rpm better than my old vg30 highflow.
and what do you class as fullboost?
RB25det with same turbo will archive full 24psi of boost by 3800RPM. But obviously we recommend .82 housings for BR25det as its limiting power out put. RB20's are ok with .63 rears due to smaller engine size.
Yea I'm also curious how you get a good reading and pressure, without breaking the hard plastic with the clamps. Ideally, you'd want to retrofit the AFM into a metal pipe, but I guess what you've done works well enough.
BTW, what is the narrow pipe with wrapping going up in the 1st picture? Is that your BOV plumbback?
is that the same as mine stao?
Yes same as yours. I've sent every thing back last week. Its got the wastegate controller installed. So you can play with that to get external gate's result.
Fitting AFM in between cooler piping, it avoids engine stalling problem every time you back off the accelerator running none or atmosphere bov with metal intake pipe. That plastic casing won't crack. My sil180 has the same setup and I run it 24psi. The only thing do happen to them is the plastic casing covering all the digital components do gets blown away by boost resulting a massive boost leak. Just Ziptie it tight.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
