Also if I run external gate and plumb it back, then wouldn't this be considered as road legal "internal" gate?
How effective is an external gate plumbed up to the internal gate location?
It wouldn't be legal as it would be seen as a form of boost control modification.
I'll be interested to test it only if its rated road legal. I received a $760 fin from EPA (01/01/09 first day of 09 lol) in Vic for having an externally bleeded gate. I will be more interested in developing a street legal sort of setup.
I'll be considering to do those sort of setups if plumb back is legal.
and plumb screamer back in to the front pipe.
Where did i say 1000rpm better response? I didn't.
I said quite clearly - power band. Useable RPM range.
All your dyno sheets tend to end @ 7,000rpm.
Most results you've shown tend to show a drop that usually starts around 6500rpm - a power band of 2500rpm (4000-6500).
If the sheet goes to 7500 (i think i saw one?), the drop was quite big (30-40rwkw IIRC).
To date you've not really answered when questioned about it in 2-3 threads now, and I'm not the only one that keeps asking.
I've not seen a 3071/3076 drop off that harsh ever.
i have to agree, my old high flow which is the same one that held 20psi all the way to 7200 also did not drop off, just flattened out at 6500 and held the same power to 7200.
And Stao, blaming every dyno curve that drops off on wheel spin is getting a little old.
Strap the car down better, but if its not wheel spinning at peak torque i doubt it will wheel spin once the torque drops off at high rpm.
2 things, your first comment is void - nobody plumbs it back to the factory gate position. The idea is they plumb it into the front pipe later down the exhaust.
2nd point, it is legal from an emissions perspective however ANY modification in just about ANY state is considered illegal.
You highflow, is as illegal as it gets.
it isn't blatantly obvious to anyone who sticks their head into the engine bay though...
One other thing popped into mind, wouldn't say a Garrett core inside stock housings make the compressor flow all kinds of f**ked up?
Yep, hence the 1500rpm power band and massive drop off after 5500rpm
Its due to the massive wheels inside small housings, same goes with the ct12 highflows that many companies do, all that achieves is a shit load of lag and maybe a 15rwkw gain overall for the soarer guys, because the housings just cannot flow enough air, so you stick a shit load of boost through them and all it does is superheat the intake air.
But on the same time I don't think your high flow made that much power either. Keep in mind this is 305rwkws final result. It doesn't seems to affect power under 260rwkws. Can you scan a copy of your sheet?
Plus I've never blamed wheel spin for drop off. Its blamed for incorrect RPM reading. So at moment I'm doing all my runs on a hub dyno.
I think I can get away from the drop with internal gate on high powered applications. Stay tuned.
It will wheel-spin at peak power not peak torque, sure the torque drops off but the overall power keeps climbing due tot he increase in rpm.
Edited by Rolls
Not in my experience, torque is what turns the axles/accelerates the car, hp/kw is just torque x rpm
Eg, I have driven quite a few big power NA big block bent eights, on the road they all broke into wheel spin at around the peak torque rpm, but hold at high rpm in the same gear and plant it they dont.
Just looking back to this high flow:
The final tune peeked 305rwkws at 6500RPMs and droped 15kws at 7000RPMs which still made it 290rwkws at rev limiter. I think its good enough as far as high flow goes thou.
But I consult with Tuners and engineers to see if this can be straightened by modifying few things.
Also when wheel spins. you lose peak power, torque and get incorrect reading. Note 2x power curves of the ATR43G3-P1 test runs. with and without people in the boot. That shown lots wheel spinning, and less wheel spinning.
This is my experience as well with various different high powered cars.
So that one holds to 7000rpm, but power comes on like a switch, it doubles its power in the space of 200-300rpm.
If you can fatten up the mid range and bring it on boost smoother it would be a winner.
Not it isn't, power is. Even though there is less torque there is more work being done (more power) so even though the actual force per cylinder explosion is lower there are more explosions going on. If that were the case everyone would make their cars massively under-square with huge strokes and tiny bores, sure it makes loads more torque but it makes less power and is hence slower.
That is all due to the rate that power increases, eg turbo cars break into wheel spin when the turbo kicks in due to the massive slope in power, it has nothing to do with the amount of torque though. Basically the wheels break traction then they increase in rpm, that increase brings about more power and makes them spin even more, where as at the higher rpm the power level is flat or decreasing, this means when they break traction the revs increase and hence it is making less power, this means the power drops below what is required to spin the wheels and it hooks up again. Nothing to do with torque level and everything to do with the slope of the power curve.
Really good article here on why this is the case.
http://autospeed.com.au/cms/title_Power-ve...48/article.html
Edited by Rolls
Maybe its just a coincidence that the greatest slope in power is normally around the peak torque.
Stao I wouldn't give a piss about those haters. There is noting wrong for putting effort on building cheaper and more convenient setups.
One thing I must point out thou. Have a look at your others sheets. It looks like this sharp tip off is only with your car. Heat from or boost drop formed power drop would round off a lot more smoother "blow" while your is just a sharp Tip. Looks like a rev limiter kicked in early or a miss fire. Get Status to checked it out before you tune.
Note there is no drop off at Harey's reading, whom is running your old turbo.
Edited by kwickr33
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
