Tell me it's not true :(
I am just about to get one of these Nistune Z32 ECUs installed in my R33!
@Darkhalf please sort this out and give us confidence in this product...
I'll be over $1000 out of pocket and not very happy if my tuner (not Trent anymore) can't get this solution working!
I look forward to an update mate
Lets get this straight it is not a nistune issue as much as an incompatibility between some Z32 ecu's and the R33 car itself, we have done about 20 or so (upto 400rwkw) and of those 20 about 6 give major headaches (r32 nistuned ecu worked so its not the cars), since i cannot differentiate the exact problems between ecu serials and r33 model series1, 2 or 2.5 i have stopped doing them, Stao's latest issues were the 16bit ecu.
Nistune is a great system and is generally our Number 1 recommendation for S13, S15 and R32 / R34's.... just not R33 with ecu conversions :P
+1
Just use the rb20 ECU and an MSD switch/eboost street ffs guys
Its like $150 MAX for the switch and the rb20 ecu are dime a dozen.
It is a non issue, just sell your Z32 one and use RB20, no rewiring for knock sensors etc needed it just works.
On another thought its a good thing. Because Trent stopped you from dumpping thounsands of dollars in trouble shooting and headaces.
Toshi is comming to melbourne for remap you can just get that for $500. Or I can supply you a adaptronic ecu for $1000.
or he could get a nistune rb20 ecu which is better than either of those
Edited by Rolls
Actually Stao it was precisely because of Trent talking up this Nistune Z32 ECU solution for the R33 that I purchased one in the first place! (through him)
I will wait to see what Darkhalf comes back with...
Contrary to what Trent says this is a 100% a Nistune problem - except of course when you are using an unapproved 16bit ECU!
Nistune sell this solution for the R33 so they are obliged to sort these issues out and get it working.
My Z32 ECU is on the Nistune approved list and was modded by them in SA - I damn well expect them to get it working! :mad:
P.S. I just spent a bazillion dollars on turbo, injectors, clutch etc and didn't leave myself budget to buy a $1000 ECU
@Rolls - Thanks for the advice mate but I got this Z32 ECU because Trent and everyone else were adamant that it is a better solution than the R32 ECU.
Edited by Checkbuzz
Stop whinging that the product does not even work if you don't even know if it works or not on your car...
Trent said he's tuned 20 of them and 6 out of 20 had problems, thats 30% risk out of “supported” ecus. Stao's S2 R33 with 16 bits z32 ecu can't even drive properly, and he's out pocket for 6 hours tuning, that already $1000 spent. What amuses me from Darkhalf's reply is that they've still chipped that ecu knowing it’s not supported / won't work.
Sale that ecu to who ever wants to tune it, then get a proper ecu, or wait till they fix up their bugs.
I had the z32 in mine also.
Played up constantly and they could never get it right. Gave me the shits
Changed to a r32 ecu but now no vct. Ive got an Eboost Street so apparently theres something that can be done there. But in short I cant be bothered finding someone who will know how to do this, as clearly i dont.
In my personal experience everything that gets tinkered with, seems to effect something else until the car shits its arse.
All good though if your a mechanic and can sort these issues out without paying through the nose....
Edited by Mattw_83
This isn't how you win friends and influence people.
http://nistune.com/docs/Z32_ECU_Modifications_Direct_R33_Plugin%20V6.pdf says:
2) We recommend Z32 (8 bit) ECU’s for this modification. These can be any JDM , EDM or 1990-1992 USDM model ECU. It does not matter if the ECU is naturally aspirated or turbo, manual or auto.
(Nissan part numbers 23710-30Pxx, 31Pxx, 37Pxx, 40Pxx, 41Pxx, 46Pxx, 47Pxx and 48Pxx).
Avoid later model USDM (1993-1996) 16 bit Z32 ECU’s (Nissan part numbers 23710-45Pxx, 53Pxx, 51Pxx).
3) Note that most USDM Z32 ECU’s are not stamped with a Nissan part number. However there is a manufacturer (JECS) part number which begins with A18. We can work out the Nissan part number if you contact us with the JECS part number, or you can connect to the ECU using any consult tool to retrieve the Nissan part number.
Have these guidelines been adhered to?
How does Nistune compare with a Dr Drift style tune where a daughter board is installed for an R33?
I have been using one of these for the last 3-4 years with no dramas. The only problem so far is finding someone else to tune it. Nothing wrong with Dr Drift tune but he is often booked out for weeks
Jimmy
So what should do you think I should do? Spend $600 and have a punt to find out?
Oh and BTW that tuner who was the "go to guy" for these things now won't touch them with a barge pole... excuse me if I am not filled with confidence
I would not be bagging out a manufacturer on a public forum when you haven't even used the product so have no idea if it works or not.
Trent said he's tuned 20 of them and 6 out of 20 had problems, thats 30% risk out of "supported" ecus. Stao's S2 R33 with 16 bits z32 ecu can't even drive properly, and he's out pocket for 6 hours tuning, that already $1000 spent. What amuses me from Darkhalf's reply is that they've still chipped that ecu knowing it's not supported / won't work.
Then get an rb20 ecu, its guaranteed to work.
Why is this discussion even being held in this thread?
If you've got an issue, talk to Matt @ NIStune, if you're not a c0ckhead he will most likely help you sort it out. But until you actually RUN the ecu you don't even know IF you have a problem or not (it has been said that not ALL 16-bit ECU's have issues).
You're obviously having second thoughts so you might as well get rid of it and use whatever your new tuner suggests you use and be done with it.
Settle down mate... Who is bagging who?
All I said was that if there is an underlying issue with the Z32 ECU here (which appears to be the case) then my expectation is that it's Nistunes responsilbility to resolve it.... which they appear to be doing. Clearly I am not happy with this situation and other people telling me to just buy another ECU is not the answer I'm looking for here.
When the tuner who was the "go to guy" in VIC for these things turns around and tells you he won't touch them with a barge pole I think there is a little problem no?
I don't see what you are whinging about. You have an ECU that is on the approved list, why are you now assuming it is not goin to work before you even try it? My mate had a Power FC that shat itself. Does that now mean all Power FC's are shit and not going to work? At least with NIStune, Matt will try to help you.
If you've followed the guidelines That jrm posted then give the ECU a go before bagging it out. If you haven't, don't blame the company for it.
If you're not prepared for expensive set back, don't modify cars. Of course the more you modify the more likely things are to stuff up.
I agree with Bubba, this is not an issue that should even be discussed in this thread.
you have clearly missed the point
clown.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
