Are the stock BOV and breathers currently plumbed back into that bit from the factory intake pipe?
Any way, further updates with the SS-3 unit. This turbo is made for 350rwkws with optimum response. To make this work at its full capacity as possible I’ve replaced my factory exhaust manifold with an aftermarket item. The new manifold held the turbo at factory position, so stock dump and exhaust lined up fine.
In car:
With the new manifold it feels awesome at full open throttle, how ever it also feels like it have added lag down low. I will do a back to back comparison with the SS1PU after this run.
Fairly sure the AU onwards has proper double wishbone and IRS suspension so should drive a lot nicer than a EL, especially with some decent bushings/shocks/springs.
IRS was an "option" for most AU's.
But the handling is better than an EF series 2, so most likely nicer than the EL as well :)
Some interest turbo development Stao :)
I will
Be saving up for this ss-3 unit...!! Looks tempting to me!!..Whats the supporting mods for this set up A-Z list please if u could..im really keen..
You haven't even seen the results yet?
I bought that off a guy on ebay for $400. I think its a coated ebay manifold. I've fitted the SS1PU back on it seems to have lost abit of response on partial throttle, how ever does seems to delivery wider torque range on wide open throttle. I might do one comparison run using the SS1PU first, to see the behavior of the power and torque delivery due to this aftermarket exhaust manifold.
yeah that would be very interesting..
it looks the same design as the HPI, the ebay ones are alot different in pipe design..Unless there is a HPI copy I dont know of..
ED..ok found em in UK..cheap too..
Tuning the ss1.5 on saturday morning. Just fitting the 740cc highflows fron ebay use at the moment. Flow fairly even but spray is like a hose.
would be interested to know how the injectors go.. aswell as the turbo ofcourse
Those manifolds seems to work fine. If it can get me a certain percentage of extra power and torque then I won't need to design a huge turbo reaching target goal.
Also every thing fitted and lined up fine.
I will make this SS3 externally gated through turbine housing.
Tao would you be able to mod any housing of your turbos to be externally gated from the bottom the housing with a 38mm vband flange to it? I'll be interested to see how this housing performs. I wanted to get a old housing on one of my planned turbos a while back modded to have the wastegate on the housing but I kept thinking there may be some turbulence and flow interference in it so ditched it. I really would love to run a screamer pipe lol and have a my dump customised to suit either a plumb back external gate setup or an atmo external gate setup.
Tao how well do you rate those TFI pod filters? I really need to know if my apexi power intake is a restriction...
Yes can be done, how ever big external gates are more effective when working with big turbo in small turbine housings. The SS2 and SS1PU versions has welly matched wheel size and housings. It might not make much difference in that setup.
I got the TFI filter for $10 inside discounted tray at Autobarn. lol. Its a 4inch filter with 2 set of sleeves. Worked fine, didn't had any restrictions at all.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
