I have been thinking though. The stock turbo was set to 13/14psi but in cold weather had no trouble pushing over the boost limit though my intercooler and it's a much smaller turbo.
One thing to note on my current setup is my actuator gets it's boost feed from the cold side of the intercooler so technically the turbos wastgate should be shut tight when my boost starts to drop.
Rolls - that's why I'm here, to see what people have on their cars. I think I should actually use what ever stao has on his test car as it "should" give similar results.
Yes but your new turbo is now flowing much more at that given boost pressure.
You should hook the actuator to the nipple on the compressor, why on earth are you running it from the IC?
Re using the same IC as him that is a really good idea, at least you are removing another unknown that way.
Edited by Rolls
There isn't a nipple on the compressor. The fitting that used to go to the charcoal canister was the closest fitting I found.
FAIL!
This will be half your issue... Run it from the compressor cover or the cooler piping BEFORE the intercooler
that is weird that it doesn't have a nipple on the compressor housing, are you using one of HGs aftermarket housings? If so how does he set them up?
If anything though running the hose from anywhere else should cause boost spiking, not bleeding off.
Edited by Rolls
I think its best to send it back and swap for a FNT G3, I can give you my 330rwkws nistune map, load it in and see if that changes boost and power behavior, That turbo should also suit your driving style better.
Ok I'm sick of playing this game now. Now it only makes 16psi and nothing has changed
You're changing it's symptoms, that's a good thing. Just keep working through it.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
